Indicator WL dim and beeper quiet ?
Old Mar 12, 2023 | 04:24 PM
Pistnbroke's Avatar
Default Indicator WL dim and beeper quiet ?
Any thoughts on this ///dash has LED bulbs ..all bright except the indicator repeater arrows. Also where is the diagram for the indicators in jag repair.com
Old Mar 12, 2023 | 04:53 PM
motorcarman's Avatar
The diagram is S97_XK8.pdf
The column loudspeaker often fails and needs replacement.(LJA2282AA---64 Ohm and I think 66mm diameter)
Old Mar 12, 2023 | 05:00 PM
Aarcuda's Avatar
awesome do you have similar information for an 06S type? because I’ve got no chimes or tones for anything so I believe the speaker in my car is bad. I’ve looked at the Live data and it shows that it’s trying to make sound, but nothing comes out.
I believe the speaker is inside the instrument panel but I haven’t taken the part yet, but I’d love to know what the part number is, or if I can geta speaker as a separate item. or match something to it that would work It’s just not that much information out there about that speaker other than it’s in the instrument cluster
Old Mar 12, 2023 | 07:54 PM
Figure 07.1 in the Electrical Guide Instrument Cluster; Audible Warnings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . All Vehicles.
The Audible Warnings 'sounder' is part of the INSTPK. (I have no other info)
Old Mar 13, 2023 | 02:26 AM
Pistnbroke's Avatar
The speaker is behind the binacle where you put the key in .
Being thick today but where is S97-XK8 pdf.
Now I have the new flip out radio the wife has the music on all the time so was wanting to fit a buzzer to the wiring but need to have a diagrasm.
Old Mar 13, 2023 | 04:47 AM
michaelh's Avatar
Default Here you go....
Gus' site:
http://www.jagrepair.com/images/Auto.../jagxk1997.pdf
Old Mar 13, 2023 | 05:00 AM
Pistnbroke's Avatar
yes found it marked DI.....sadly the indicator switch connects to earth so not a conventional /easy system to fit a buzzer to ...will look at the speaker.
Looks like the cables to the indicators come from the body control module behind the glove box GY and GK
Buzzer and some diodes and we are away! Pins 2 and 3 ..at least its in the cab.
Rchuda
May 23, 2021 09:22 AM
nalle
Nov 8, 2020 06:30 AM
Justin84
Mar 6, 2020 09:48 AM
JackDanielsPlease
Jan 2, 2016 11:22 AM
GhostriderXKR08
Jun 13, 2013 09:14 AM
