Instrument Cluster Inop / Car will not shift out of park
Old Feb 24, 2013 | 04:36 PM
DRB1122's Avatar
Default Instrument Cluster Inop / Car will not shift out of park
Here's my issue...car starts right up, instrument cluster is not working, oil pressure and battery charge not working (clock is working), the car will also not come out of park. I drove the car yesterday with no issues / warning lights. The only error code that is coming up is on the climate control display (#14, but this is linked to instrument cluster output), If anyone has any ideas...
thanks
1998 Jaguar XK8 Conv.
4.0 Liter Engine
Old Feb 24, 2013 | 04:54 PM
WhiteXKR's Avatar
The instrument cluster is the hub of all communications, and perhaps its computer crashed. Disconnect the negative terminal of the battery for 10 seconds and reconnect it to reset the system.
Old Feb 24, 2013 | 05:13 PM
DRB1122's Avatar
Default That was the trick
Thanks...It worked!!!!!!!!!!
Old Feb 24, 2013 | 06:07 PM
WhiteXKR's Avatar
Great!!
If it recurs, check your battery. Also check the primary power connections at the battery, the two high power fuses connections behind the spare tire well, and the primary power feed connectons to each fusebox. Sometime the bolts holding down these power connections work loose.
Old Feb 24, 2013 | 06:09 PM
Welcome to the forum DRB1122,
Now you've successfully got over the Instrument Pack panic, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice on posting to the forum.
Old Feb 25, 2013 | 11:00 AM
DRB1122's Avatar
GGG, I went through the new member intro yesterday before posting...I am trying to add a picture and the other information but it says I can't access the area?
Old Feb 25, 2013 | 12:51 PM
I was meaning posting an Intro about yourself in the New member Area section ( New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum ) and not forum registration.
Are you trying to add pics to a post here or to your forum user profile?
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
peterg19
Aug 30, 2015 08:48 AM
looops
Aug 28, 2015 06:18 PM
Drew2006
Aug 28, 2015 04:22 PM
