Intermittent ABS Light Issue
Old Dec 8, 2024 | 01:59 PM
thom4782's Avatar
Default Intermittent ABS Light Issue
Hi everyone:
I have a 99 XK8.
For the past year, I've experienced an intermittent ABS issue where the ABS light comes on at start uop and the dash shows a "stability control failure" message. The light and message show until 1( I turn off the ignition and restart the car and 2) drive for 100' or so at which point the light and message clear. While it may be a coincidence, this started when I picked up the car from repainting.
My guess is there might be a dirty or failing wheel speed sensor. Or it could be something else. Any thoughts on what might be the problem and how I might diagnose it further. If I take the car to the local shop, I'm sure they will recommend buying new parts.
TIA
Thom
Old Dec 8, 2024 | 04:22 PM
b1mcp's Avatar
I will guess that it's a ABS pump issue, or may be just weak battery.
But guessing isn't the way to go. The absolute first thing you must do is read the codes. There will be one (at least) stored. That will give you a big pointer as to where the problem lies. Then go from there.
Old Dec 8, 2024 | 05:24 PM
motorcarman's Avatar
Without DTCs we are all just guessing.............................. Let the guessing begin...............
95 Cat
Jun 27, 2023 01:39 AM
Oscartblossom
Jan 27, 2015 08:34 PM
fidget247
Sep 30, 2010 12:01 AM
Spurlee
Jul 14, 2009 02:46 PM
jaysto
May 27, 2009 01:17 AM
