Jag XK8 ABS module removal (1997)
Old 05-11-2019, 04:44 PM
iankke's Avatar
Default Jag XK8 ABS module removal (1997)
Having the ' well known' problems on my XK8 of the ABS warning and traction control warning coming on. I have taken out and cleaned all 4 sensors but to no avail. The next step will have to be taking out the ABS control module and re-soldering the problem areas on the board or sending it in for repair.
I am not keen on taking off the brake lines from the block and then having to bleed the system.
Anyone have experience taking the module out without disconnecting the brake pipes?
Old 05-11-2019, 05:28 PM
GGG is offline
Received 16,829 Likes on 12,179 Posts
Welcome to the forums iankke,
I've moved your question from General Tech Help to XK8/XKR forum. This is the place to post technical questions about your vehicle
djpxk8
10-30-2019 11:47 PM
69merccougar
01-20-2015 05:45 PM
Joedudejag
11-04-2014 11:25 AM
Quick Reply: Jag XK8 ABS module removal (1997)
