Jaguar XKR radiator fan vibration
Old Jul 25, 2013 | 10:07 PM
Jannas's Avatar
Default Jaguar XKR radiator fan vibration
Hello Gents,
I have a new problem with my XKR. Stopping her after a long drive, I heard a lot of vibration when I drove into the garage. The left fan in the radiator housing was vibrating like crazy. I'm not sure if it's the bearing inside or harmonic vibration from the housing since there is a missing screw or bolt on the top left side, I've noticed hole.
Can anyone identify what kind of bolt or screw I need to fix my loose radiator fans?
Thanks for your help.
Old Jul 26, 2013 | 06:30 PM
The Cooling Fans /Cowl assembly is secured with two M6 nuts (item 3):
(click on the diagram to enlarge it)
It's unusual to lose the nut. More often the nut together with the stud it fixes to works loose and falls out.
The Radiator is fixed with 5 torx screws (item 10) through the Mounting Panel (item 9):
Loss of one of these shouldn't give rise to excessive vibration. Any one or more of the Mounting Bushes (item 6 & 7) failing or the moulded pegs on the radiator (arrowed in red) breaking, allows the Radiator to vibrate.
Old Aug 17, 2021 | 08:48 AM
JayJagJay's Avatar
Attachment 49244
Attachment 49241
Does anyone have a source or part number for number #12 in the diagram Graham posted. I've been struggling to find it or anything like a replacement... Any help would be greatly appreciated.
Old Aug 17, 2021 | 10:39 AM
Jon89's Avatar
I lost one of those square-headed bolts a little over three years ago while pulling the alternator for refurbishment and replacing the serpentine belt at the same time. I wound up using a similar-sized brass bolt and washer from my loose screws-and-nuts collection. The replacement bolt was not square-headed but the matching washer I utilized fit snugly down into the slot where the square head goes. It is still holding firm today....
I hoped that the lost OEM bolt would show up underneath the car but alas it never did....
Old Aug 17, 2021 | 01:17 PM
JayJagJay's Avatar
Got ya. This is for the XKR I've been working on. On my XK8 I swear I did something similar to what you've described, and like you, with success. For some reason I've been struggling to get that same idea to work in the XKR. More, due to the proximity of the belts, pulleys and moving bits I'm a bit more afraid of a failure on the XKR. You know, the bolt turns itself loose and then, all hell breaks loose. I would love to get my hands the right fasteners.
When I try to use a bolt, buy the time I get the nut snugged down, everything is spinning...
Old Aug 17, 2021 | 01:38 PM
michaelh's Avatar
JZB100066. 'Someone' had lost one from my car and replaced it with a filed-down bolt.
Heritage carries them for less than $1, so best get your order in quick. They'll be flying off the shelves
Old Aug 17, 2021 | 01:52 PM
JayJagJay's Avatar
BeaUUUUtiful, Brotha! Thank you. Just ordered 6 of them. I'll use the two,,, then loose the other 4 in a bin somewhere, lol... To be discovered in 3.7 years. Jus the way it is...
Thanks Michael!
Andrew Harper
XJ XJ12 ( X305 )
May 23, 2017 04:59 AM
zeropegleg
Feb 18, 2017 07:26 AM
Lcgi
Oct 25, 2014 01:21 AM
aholbro1
19
Oct 4, 2012 03:19 PM
03Xtype
Apr 22, 2012 11:04 AM
