Jaguar xkr x100 convertible roof won't retract
Old Jan 25, 2026 | 02:12 PM
jagman1642's Avatar
Default Jaguar xkr x100 convertible roof won't retract
Hi having trouble with the convertible roof on my xkr x100 I Press the button the rear windows lower but there's no noise or movement in hhe actual convertible roof the fluid in the reservoir is green and is showing very minimal in the tank any ideas thank you
Old Jan 26, 2026 | 02:40 AM
dibbit's Avatar
When you say "is showing very minimal in the tank" do you mean the hydraulic fluid is low?
This is your starting point to work out what is going wrong:-
Jaguar XK8 Roof Troubleshooting 1997 - 2006
JagRepair.com - Jaguar Repair Information Resource
Old Jan 26, 2026 | 08:04 AM
MikeGriese's Avatar
If the tank is almost empty, that is why your top isn't working. But that is just a symptom. The problem is why the fluid is low. If you weren't getting green fluid leaking out of the windshield header, one (or both!) of your lift cylinders or the hoses servicing them are leaking - a LOT. You should see evidence of hydraulic oil somewhere in the trunk or back seat floor areas.
Old Jan 27, 2026 | 08:45 AM
Warmuthb's Avatar
”Yes” to what Mike and dibbit said above... If the fluid is low (very low?) then it is going somewhere; ie., you have a leak. Fast or slow you still have a leak. Your job is to find it. Filling the reservoir before finding the leak may make the top work better for awhile, but you still have a leak. Perhaps it will reveal itself. Perhaps there is more than one.
Best of luck but the most likely cure if the lines and or connections are leaking and are original is to replace all the lines and have the three activating cylinders properly rebuilt.
Brian W.
wda80128
Jul 19, 2025 09:15 AM
PrettyA
Jun 11, 2025 06:41 AM
Klaus0401
Mar 24, 2025 10:02 PM
brinny
Apr 5, 2020 09:47 AM
Jagman46
Nov 6, 2017 08:28 AM
