James Bond Smoke Screen
Old Jan 10, 2014 | 02:14 PM
Mr. Feathers's Avatar
Default James Bond Smoke Screen
Hello all,
When I coast downhill for any amount of time, then push on the gas, my '97 XK8 emits a smoke screen behind me. I cannot quite discern the color, but I'm thinking it is unburned excess fuel - as some of it gets drawn into the cabin and smells like an extremely rich condition / unburned gas. I would think that if the rings or seals were bad & oil was being drawn into the cylinders from the increased downhill vacuum, that it would smell like burning oil (which it doesn't).
What should I put at the top of my troubleshooting list? Too much fuel pressure due to a blown FPR? Would that force the injectors to leak? I do notice that my long term fuel trims are extremely negative (about -17), so perhaps there is excess fuel leaking into the chambers and the ECU is trying to lean things out in general.
Advice appreciated
Old Jan 10, 2014 | 03:05 PM
RJ237's Avatar
If there is enough unburned fuel to cause smoke, your cats are probably fouled. Oil smoke is white, a little blue. If your injectors leak, you should have black smoke at startup, and maybe difficulty starting due to bore wash. Get a fuel pressure test kit and see how fast the pressure drops after you shut the engine off.
Finbarr1975
Sep 5, 2025 08:38 PM
aode06
Jul 28, 2023 02:26 PM
Finbarr1975
Oct 4, 2015 05:32 PM
10 XF Premium
Oct 2, 2015 09:22 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
