Jtis 204-03
I had a look at the various parts pdfs but they don't seem to show the two different spacers, on my shock there are two flat black spacers and one white wedge spacer, I can't see any reference to the white wedge spacer anywhere.
On the UK 2002, look in JTIS under 2003. It appears that they have rearranged the section numbering.
Here is what they say:
For assembly reference, note the number of spring packers. The number of spring packers depends on the spring rating, some vehicles do not have spring packers fitted.Disassemble spring assembly.Release lower retaining arms.Remove adaptor tool.Remove spring pan.If fitted, remove spring packer(s).Remove spring packing washer.
This was found in 204-01, Front Suspension, Spring
UKnFor-dluv-expat
Sep 26, 2015 08:40 PM
