JTIS for replacing a 97' XK8 radiator?
Old Oct 6, 2013 | 09:04 AM
Windycityx's Avatar
Default JTIS for replacing a 97' XK8 radiator?
I have a radiator leak on my 97' XK8 radiator, can someone post the JTIS on how to replace it? Thanks!
Is there some kind of epoxy I can use to stop the leak until I can get it replaced? It drips and then it steams from my hood after light driving....
Old Oct 6, 2013 | 09:30 AM
Jag#4's Avatar
JB Weld makes an epoxy called WaterWeld that is designed for use with water applications and takes high heat well. I used it on the plastic side tanks on my leaking radiator.
Probably will hold forever, but I had to replace anyway as it developed another leak further down and I decided the tanks were too compromised to trust.
Old Oct 6, 2013 | 09:33 AM
Jag#4's Avatar
And here's a thread on replacing the radiator, which includes the JTIS pdf.
https://www.jaguarforums.com/forum/x...adiator-60937/
Old Oct 6, 2013 | 09:52 AM
Windycityx's Avatar
Where can I find the JB Weld Water Weld and I looked at all the threads but wasn't sure if it was the same as I have a 97' and that was for a 2001?
Old Oct 6, 2013 | 10:42 AM
Originally Posted by Windycityx
I have a radiator leak on my 97' XK8 radiator, can someone post the JTIS on how to replace it? ......
Here's the JTIS procedure for 1997 Radiator removal and replacement:
JTIS - XK8 1997 Radiator Removal & Replacement.pdf
toronadomike
Jan 22, 2026 10:13 PM
kelliott
May 31, 2022 05:26 PM
David Thompson
Sep 3, 2015 07:48 PM
KarimPA
Sep 3, 2015 07:32 PM
TC Johnson
Sep 2, 2015 09:30 AM
