key fob issue fixed
Hi all:
Have a 99 xk8 convert and the key fob slowly got worse and worse. Replaced the batteries and did nothing. Using the key for awhile and I finally took it apart. Wow is all I can say. I guess the sweat of years and maybe coffee etc had turned some of the rubber to a slimy gel like material. It was a real mess. I used small cloth and some rubbing alcohol and also cleaned up the pc board. Although the small contacts were worn I put it back together and it works like a charm from a good distance away now. Easy fix and its never worked so good
Howard
Howard
99xk8guy
Sep 29, 2025 10:51 PM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
Nov 23, 2015 01:56 PM
