key fob issue fixed
Old Jul 26, 2012 | 04:47 PM
hdsg's Avatar
Default key fob issue fixed
Hi all:
Have a 99 xk8 convert and the key fob slowly got worse and worse. Replaced the batteries and did nothing. Using the key for awhile and I finally took it apart. Wow is all I can say. I guess the sweat of years and maybe coffee etc had turned some of the rubber to a slimy gel like material. It was a real mess. I used small cloth and some rubbing alcohol and also cleaned up the pc board. Although the small contacts were worn I put it back together and it works like a charm from a good distance away now. Easy fix and its never worked so good
Howard
99xk8guy
Sep 29, 2025 10:51 PM
philwarner
Oct 4, 2024 01:37 PM
JarodL
Mar 7, 2024 01:39 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
XJsc-guy
Nov 23, 2015 01:56 PM
