key for not working 1998 xk8 x100
Old Aug 31, 2025 | 12:03 PM
jmstunts's Avatar
Default key for not working 1998 xk8 x100
I have 3 key fobs that were working, then 2 stopped and the third was intermittent, now none work. I can get the learning mode to work on the car, but none of the fobs respond. I did clean the contacts, used the button restore compound, but now nothing. Is there a separate fuse for the fob antenna or is it powered from the security module? Any advice, will the IDS system detect problem?
Jack M
Old Sep 1, 2025 | 03:25 AM
dibbit's Avatar
There is a recent thread on this. You need to check your remotes have the correct batteries (2 per fob, not 1) and the aerial:-
https://www.jaguarforums.com/forum/x...t-open-290612/
Edited to add: check fuse 10 in the boot fuse box. If your fuel flap release button or boot release button on the dashboard work then your security and locking module is working.
Old Sep 1, 2025 | 09:24 AM
Gus's Avatar
Gus
Read this cleaning process and see if it helps.
JagRepair.com - Jaguar Repair Information Resource
Also try to reprogram the remote to the car.
http://jagrepair.com/JaguarXK8RemoteProgramming.htm
Gus
Old Sep 1, 2025 | 09:35 AM
jmstunts's Avatar
Thanks, I have already done all of those steps, correct batteries, cleaning contacts, using button restore paste on rubber buttons, all 3 were working at one point, and now none work....I think there is an issue with the key fob antenna, if all else fails maybe do a little sage smudge.....1998 xk8 convertible....
Jack M
jmstunts
Sep 1, 2025 06:26 PM
jmstunts
Jul 28, 2025 09:55 AM
andyzeg
Jun 15, 2024 05:57 PM
JagJoe80
Apr 21, 2018 06:34 AM
jnporcello
Apr 29, 2015 06:48 PM
