Last ball Joint Question
Old Jul 13, 2019 | 04:01 PM
funracer's Avatar
Default Last ball Joint Question
Tested my old ball joint today and it moved around pretty much as I expected. I also expected the new BJ
shaft to move around smoothly but in fact it does not move at all. None of the four do. Not even when you tap
them with a hammer. The shafts are frozen and don’t move at all. Is this normal for a new ball joint? I have
the right upper installed on the control arm and since it will not move it is difficult to line up properly with the mounting
hole. Thanks
Old Jul 13, 2019 | 04:20 PM
Jon89's Avatar
That new ball joint should move freely in order to function properly. Can you tell why it is seized up?
Old Jul 13, 2019 | 06:16 PM
baxtor's Avatar
hole. Thanks
I can't see all new joints coming to you seized. New will normally be much stiffer and have more resistance to initial movement but movement will still be smooth when it occurs.
Old Jul 14, 2019 | 04:18 PM
funracer's Avatar
Went to AZ today they pulled out a new ball joint from the back for a comparison. I could not move it either
so I guess its normal. I will carry on tomorrow.
Old Jul 15, 2019 | 05:23 AM
Went to AZ today they pulled out a new ball joint from the back for a comparison. I could not move it either......
You need a can of spinach.
( I checked your DoB to be sure you're old enough to remember the Popeye cartoons before I posted this)
Old Jul 15, 2019 | 10:01 AM
funracer's Avatar
Haha that is true no doubt. I’m pretty sure I would lose at arm wrestling to Olive Oyl.
louismacrides
Nov 12, 2018 12:19 AM
Johnken
Sep 9, 2017 08:31 AM
lsp
Oct 8, 2016 05:09 PM
adriaxj8
Oct 18, 2013 11:15 AM
stevo1959
May 8, 2009 08:43 PM
