length of hydraulic hose for the roof pistons
Old 04-19-2012, 07:48 PM
Gus's Avatar
Gus
Gus is offline
Received 2,209 Likes on 1,701 Posts
That is a difficult question to answer without knowing the rating of the hose and the connectors? The existing system reaches 1600psi
Old 04-20-2012, 04:27 AM
steveinfrance's Avatar
Gus, I'm sort of hoping that limiting the pressure to 1000 psi will help the cylinder seals last a bit longer as well as the hoses.
Old 06-24-2012, 09:26 PM
wlbusmcr's Avatar
Hello Everybody,
As was predicted, I had a failure as well on the cylinder hoses for the top and am looking at replacing with brake line hoses that have about 6000-7000 psi burst.
Thoughts?
Thanks,
Bill
Old 06-24-2012, 09:32 PM
Gus's Avatar
Gus
Gus is offline
This is for the fluid JagRepair.com - Jaguar Repair Information Resource and this is on the hose JagRepair.com - Jaguar Repair Information Resource I hope this helps.
Originally Posted by wlbusmcr
Hello Everybody,
As was predicted, I had a failure as well on the cylinder hoses for the top and am looking at replacing with brake line hoses that have about 6000-7000 psi burst. Questions is, the green fluid, Petrosin(sp?) is a power steering fluid. Why not transmission fluid which is used in industrial hydraulic applications? Or standard power steering fluid?
Thanks,
Bill
GGabriel
11-22-2018 03:53 AM
Pristine97XK8Convertible
04-28-2017 11:08 AM
emilime75
XJ XJ12 ( X305 )
10-19-2015 09:55 PM
xjrjag
10-12-2015 03:16 PM
thedugger1
09-26-2015 10:27 PM
Quick Reply: length of hydraulic hose for the roof pistons
