limited performance warning 99xk8
Old Nov 10, 2012 | 02:42 PM
espy1949's Avatar
Default limited performance warning 99xk8
hi guys, recently my restricted performane warning light has been coming on. sometimes there doesn't seem to be anything wrong with the way the engine is running and other times it runs rough. usually when you restart all is well then intermittently the light will come on. just wondered if anyone out there has experienced this type of problem and what it might be any input would be greatly appreciated
Old Nov 10, 2012 | 07:23 PM
Time to get the codes read.
Warning lights and error codes may seem like a nuisance at times but they do provide valuable information and advance warning of potential issues.
If you don't have access to a scantool, Autozone or similar can read them for you.
Ask for the actual codes (not the descriptions) and post them back here for advice on what they mean and any recommended action.
Old Nov 13, 2012 | 04:17 PM
espy1949's Avatar
Default restricted performance warning light update
thanks graham, i took your advice and went to my buddy's garage to have the codes read. the codes were so messed up that just about every fault was activated. one thing stood out misfire #4 cylinder. that particular model states that each side of the engine has cylinders 1 thru 4 (according to all data) all seemed fine on the driver side in terms of coils and plugs. however, on the passenger side every coil pack had a heavy coating of corrosion. i removed the little spriong and steel wooled all the contactors and boom problem solved it runs the nuts. thanks again graham steve
D.K
Dec 10, 2023 02:05 AM
bdboyle
Sep 16, 2019 05:58 PM
wannajag
Sep 22, 2015 08:29 PM
Johnken
Sep 15, 2015 05:46 PM
XFR_Gold
Sep 2, 2015 12:24 PM
