lincoln ls parts
Old Jan 22, 2013 | 02:13 PM
stevepaa's Avatar
Default lincoln ls parts
I plan to replace the primary tensioners, and all chains on 2001 XK8. Also water pump. Can I use parts including gaskets for 2001 lincoln LS 3.9 motor?
Old Jan 22, 2013 | 02:24 PM
test point's Avatar
I can personally attest to the fact that the upper tensioners and gasket set works. Can only assume that the primary stuff fits.
Old Jan 22, 2013 | 03:36 PM
stevepaa's Avatar
I went looking on titus ford and there is a break point for ls engines at 5/14/01, different part numbers and prices before and after. The front cover looks slightly different.
Old Jan 22, 2013 | 03:55 PM
test point's Avatar
The early LS/Thunderbird came with the same plastic tensioners, and had the same failures as the Jaguar cars prior to the conversion to the metal versions in '01 . . . 3 months before Jaguar. The part numbers posted in numerous places on this forum were originally for the '02 LS.
Old Jan 22, 2013 | 05:58 PM
stevepaa's Avatar
both sets of chains, primary tensioners, ramps, gaskets after 5/14/01 are different than before 5/14/01 and have very different pricing
Old Jan 22, 2013 | 07:18 PM
bfsgross's Avatar
Check the S-Type forum's FAQ and stickys for Lincoln LS cross-referenced parts.
Scott B
Oct 24, 2015 01:29 PM
convincor
Sep 10, 2015 06:50 AM
jaggermang
Sep 8, 2015 07:07 PM
DAN L
Sep 8, 2015 07:21 AM
1100me
Sep 7, 2015 06:26 AM
