Listen to my engine
Old Jun 14, 2024 | 06:10 PM
pcolapacker's Avatar
Default Listen to my engine
Build date 6/17/20 so second generation tensioners. Listen for after revs drop.
File Type: mov
Old Jun 14, 2024 | 07:47 PM
michaelh's Avatar
I hear a ticking which might be VVT - others will chime in I'm sure.
Beware gen #2 tensioners don't generally give any warning before they let go...
Old Jun 14, 2024 | 07:56 PM
Titled but did not yet register or insure. Planning on doing tensioners before drive any distance.
Old Jun 14, 2024 | 08:13 PM
I almost always buy from RockAuto. They have kits from INA, S.A. Gear and Preferred Components, Inc. Acceptable brands, one better?
Old Jun 15, 2024 | 02:41 AM
RichardS's Avatar
It's certainly worth further investigation. I would remove the oil filler cap and see if the noise is coming from inside the cover and use a wooden rod or similar as a listening rod to see if you can identify the location a little more precisely such as the VVT solenoid, if that is external. If removing the filler cap shows the rattling to be coming from inside, then remove the cover and do further checks.
Richard
Old Jun 15, 2024 | 03:51 AM
dibbit's Avatar
If you suspect the tensioners then you shouldn't even be starting the engine to listen to it. Take one of the cam covers off and see what generation is fitted and what state they are in. It's very easy to change the secondary tensioners as a precaution:-
https://www.jaguarforums.com/forum/x...ics-how-52653/
Old Jun 15, 2024 | 09:04 AM
Quadcammer's Avatar
Ina is good stuff and oe for many cars
Old Jun 15, 2024 | 02:12 PM
Default Cold start (97 degree day)
Not hearing tic on cold start. Video was warm engine.
Old Jun 16, 2024 | 12:37 PM
Silverjag0's Avatar
Stretched main timing chain get the tensioners and 2 timing chain from rockuto the small camshaft chain doesn't make sound or stretch
Old Jun 18, 2024 | 01:37 PM
Jhartz's Avatar
Sounds normal!
Old Jun 18, 2024 | 02:12 PM
Originally Posted by Jhartz
Sounds normal!
Even that tic when revs drop?
Old Jun 19, 2024 | 03:30 AM
laguillotine's Avatar
Shortly after buying my XK8 I noticed a noise after revving the engine, which induced a mild panic. But In that case on close inspection with the help of a friendly local Jag specialist the sound was coming from the area of the cat rather than the 'top' of the engine and it turned out it was the Cat breaking up.
Old Jul 16, 2024 | 10:39 PM
Default O-ring on VVT solenoid
Pulled valve cover and found my June 2001 engine had been refitted with third generation tensioners. Removed VVT solenoid to check. Looks like missing an o-ring. Guessing this could cause ticking by oil leaking past where the o-ring should be.
From photos on car part sites, O-ring goes here
Old Jul 22, 2024 | 01:04 PM
Default Update - pulled oil pan
Despite finding out I had third generations tensioners, decide to pull oil pan just to check for any debris. Totally clean. Checked oil pump pick up screen and also clean. FYI, you can remove oil pan without removing under engine X-brace.
Next up is transgo pressure regulator retro fit, filter change and home transmission flush.
Milopup65
Mar 11, 2021 05:50 AM
JaguarXKR
Apr 14, 2013 04:14 PM
dennisw
Nov 10, 2012 10:15 AM
snorkel54
Jul 3, 2012 09:57 PM
Rae
Aug 14, 2010 07:56 PM
