Little hard plastic coolant lines around the engine
Old Nov 13, 2021 | 11:11 PM
Silver2002XKR's Avatar
Default Little hard plastic coolant lines around the engine
Is there any reason I shouldn't replace all the little hard plastic coolant lines in the engine bay with heater hose that has the same inside diameter? The plastic is getting brittle, and I'm surprised it's lasted this long! I can probably find some hard plastic or copper tubes if there's a reason for it, but it seems like switching to all rubber would be the easiest way to go unless there's something I don't know about?
Old Nov 14, 2021 | 05:50 AM
RJ237's Avatar
I have replaced part of mine with fuel hose, not a problem.
Old Nov 14, 2021 | 08:42 AM
zray's Avatar
The only redeeming quality of the plastic hoses and the associated fasteners is their original look. Mine appear to be in excellent condition.
Nevertheless I inspect all the visible plastic and rubber hoses on practically a daily basis for any sign of leaks or swelling.
Keeping fingers crossed I can make it thru the winter without any garage time beyond an oil change or two.
Z
Old Nov 14, 2021 | 10:04 AM
Johnken's Avatar
I've done what you suggest, works great.
John
Old Nov 14, 2021 | 11:38 AM
xalty's Avatar
big rubber is hard to route
Old Nov 14, 2021 | 11:51 AM
RJ237's Avatar
That's why I used 5/16" fuel hose.
Old Nov 15, 2021 | 08:25 AM
fmertz's Avatar
FWIW, I also replace that hard line with a hose "from the garage" at some point. Over time, it turned brittle and leaky. Being cooling-related, I figured it could leave me stranded if it failed, so I caved and ended up buying a factory part again for lack of imagination.
Old Nov 16, 2021 | 12:33 AM
Good idea. I used 5/16" fuel hose with a brass tee and it went well. The only small plastic line I didn't replace was the line from the little black tank to the "atmospheric" tank in the right wheel well, because I wasn't taking that part of the car apart at this time, but when I do I'll get that one, too.
Mandrake
Sep 20, 2023 12:58 PM
alanroberts50
May 18, 2021 02:44 PM
FreakingAwesomeJag
Oct 25, 2013 12:01 PM
Aesthetic
Jan 24, 2013 02:35 PM
afonda
Jul 26, 2010 08:41 AM
