To Lock the doors ... or not
Do we know if it makes a difference to the battery drain if, while the car is sat in the garage, the doors are locked or not?
Thank you
Look after yourselves
Ray
Thank you
Ray
I tested it on my XJ8 some years ago after reading about this as I was curious. I don't recall the exact change in amperage draw now, its been too long, but the number went down a good bit within a few seconds of locking the doors. I was using a budget brand meter that I later decided was a piece of junk so I can't vouch for its accuracy even if I did remember the exact number. But it seemed to confirm the posts I'd read and I would assume the XK8 has the same electrical systems involved.
Thank you for the responses, I had always left my car unlocked in the garage and recently a friend told me he had read it needs to be locked to enter sleep mode as George05 points out.
I try to drive it often enough for it not to need charging but when I do get caught out it is usually around 10 days before its too low to start up ... I always test it by trying to open the boot with the button ... if that fails I know I need to connect the charger.
When you say double click George .... is that simply pressing the remote lock twice?
Thank you again
Ray
Thank you again
Ray
mile high
Dec 12, 2018 03:36 PM
