Low Current on Cigarette Lighter
Old Dec 24, 2021 | 08:16 AM
giandanielxk8's Avatar
Default Low Current on Cigarette Lighter
I’ve tried using the Cig lighter as a 12V outlet for a phone charger, or air compressor and have had no luck getting it to work.
Some current does reach it as it does at least turn on the led on the phone charger adaptor, but not enough to actually charge the phone or turn on the tire compressor.
Of lesser importance but related, the socket also fails to heat up the heater element in the cigarette lighter.
Electrical troubleshooting is not my strong suit, but I have a multimeter I can figure out how to use. Any clues on where to begin troubleshooting would be appreciated.
Also, does anybody know where the fuse for the 12V outlet is located?
Old Dec 24, 2021 | 08:46 AM
michaelh's Avatar
F14 (20A) - passenger side fascia fusebox.
If you're getting some power through, the fuse is likely OK. The sockets can be temperamental as they're not the finest quality in the world
Old Dec 24, 2021 | 09:35 AM
In which case, replace the socket? Or can the socket be fixed?
Old Dec 24, 2021 | 09:49 AM
michaelh's Avatar
It's usually poor contact with the centre pin on whatever you plug in, in my experience. That presses on the rivet holding the clip/+ve connector at the bottom. They quite often go rusty if the lighter has been used much. It's a bit buried to get to clean - perhaps one of those little burr wheels in a dremel?
I think the console has to come out to replace the lighter.
I have the same problem with one of the cars where I use a little plug-in FM transmitter to play USB sticks. Keep having to wiggle or twist it when it goes off
One day I'll have a go at fixing it.
Old Dec 24, 2021 | 11:12 AM
Johnken's Avatar
Giandaniel,
The fact that you get an LED illumination says fuse us ok, you're getting 12volts. Low current points straight to corrosion.
Sometimes the simplest fixes are the best. A few years ago I was going overboard trying to improve the sound as an audiophile. Don't laugh but I was actually polishing the pins on the vacuum tubes . . . Well that was until I had the pleasure of meeting Bas on line. He's the owner of Balanced Audio Technology and had worked on everything to do with tubes back in Russia before he moved to USA. I mentioned this to him, he just replied: plugging unplugging repeat is the best way he's ever found to clean the pins!
Apply this logic to your lighter receptacle. It'll work great for the cylinder, but I'd probably pull the fuse, grab some fine grain sandpaper wrap it around a dowel or a big screwdriver stick it in and polish the 12volt nub for better contact.
Hope it helps. Hey, fun fact that gentleman shared once: the MIG fighter jets actually use (used?) Vacuum tubes! Which aren't affected by an EMP pulse from a nuclear blast like a transistor is!
John
Old Dec 26, 2021 | 07:37 AM
DavidYau's Avatar
Default Checking underneath
GD,
If cleaning the centre nub, from the top, doesn't work, you may need to check connections underneath. The cigarette/ashtray compartment is a complete unit bolted onto the centre console.
It's been a while since I removed the centre console of my ex-XK8, but as Rev Sam showed it's a simple job to remove it. then you got access to the cigarette lighter. I actually had to replace it, using the cigarette lighter from my scrap donor car and I remember it was a b@#tard! to get out due to the push green lit ring. I had to enlarge the hole in the end to get the replacement in/out. From my bucket of stuff, I found these 12V cigarette lights come in different lengths, and of course Jag uses a hard to find short one. As it heats up (obbviously), make sure none of the carpet is tucked underneath it (fire hazard).
Old Dec 27, 2021 | 11:47 AM
JayJagJay's Avatar
I neeeeever knew!
Good stuff...
Yup. Clean stuff up. A hot chocolate spilled in there in 2007!
Old Dec 27, 2021 | 05:41 PM
Thanks for all the suggestions. Hopefully I can look into this tomorrow. I had my day busy changing the starter on my grandfather’s Outlander.
Old Dec 28, 2021 | 01:26 PM
Default Problem solved
After scraping the ever living hell out of that socket, I decided to check the fuse. To my surprise, what was in there was just the weirdest looking 20 amp fuse which happened to be blown.
I replaced it with a proper 20 amp spare fuse and tried my air compressor and it worked. My iPhone charger is also working properly.
Old Dec 28, 2021 | 02:08 PM
Johnken's Avatar
Nice job Doc!!!
John
Old Dec 28, 2021 | 06:10 PM
bcprice36's Avatar
Dr. Glan,
Now, where did that Weird looking 20 AMP fuse come from?
Billy Clyde
Old Dec 28, 2021 | 11:28 PM
Originally Posted by bcprice36
Dr. Glan,
Billy Clyde
My guess it was the P.O. It was labeled “Smart Glow”.
Old Dec 29, 2021 | 07:52 AM
michaelh's Avatar
Smart Glow "makes it a little easier to diagnose electrical problems".
hehe - some of them, perhaps. Explains the odd continuity:
Old Dec 29, 2021 | 09:21 AM
I suspected this, but the LED definitely wasn’t working anymore.
Old Dec 29, 2021 | 11:00 AM
WhiteXKR's Avatar
I know this was the previous owner's fuse, but a word of advice: Only use standard brand name (Bussmann or Littelfuse) automotive fuses. Fuses that are gimmicky or imported from China like Harbor Freight fuses are asking for trouble.
Old Dec 29, 2021 | 02:05 PM
Skyhawk50's Avatar
Thanks for all the info in this posting. Saved me a ton of troubleshooting.
Old Dec 30, 2021 | 11:47 AM
bcprice36's Avatar
Hey Dr. Glan,
Nice Manicure!
Billy Clyde @ Cinco Ranch
Old Dec 30, 2021 | 06:17 PM
Hey Dr. Glan,
Nice Manicure!
Haha, I let one of my hot dates give me a manicure the other day. Turned out to be a much more relaxing experience than I expected.
Old Jan 1, 2022 | 09:09 AM
zray's Avatar
do tell, what else relaxing did you let her do ?
ok, maybe off topic, but a more interesting direction than “low current @ cigarette lighter” on a cold New Year’s Day.
Z
Old Jan 1, 2022 | 12:18 PM
Z
Hahaha, if I were to discuss that this thread would need a NSFW tag.
Anthony8858
Jan 13, 2022 07:06 AM
BrentGardner
May 22, 2014 03:01 PM
XJJags
Jul 19, 2012 06:37 AM
harnack
Dec 24, 2011 03:07 PM
Jamey
Mar 30, 2009 11:19 AM
