Lower rear arm removal, inner bolt fouling steering rack
Old Apr 23, 2023 | 09:43 AM
Per's Avatar
Per
Default Lower rear arm removal, inner bolt fouling steering rack
In order to replace the lower ball joint I want to remove the rear lower arm in order to use a hydraulic press. But I cannot pull the bolt out, it is fouling the steering rack gaiter and steering arm within. The service manual does not say a word about loosening the rack. Anybody done this who could clarify? (And the front arm bolt is fouling the "X" brace. Who designed this? Grrrr!)
Old Apr 23, 2023 | 10:02 AM
Per's Avatar
Per
Rrrriiigghhtt, I found a reference in a pdf: "The XK8 Bible.pdf". It says the rack has to be dropped slightly.
Old Apr 23, 2023 | 01:21 PM
giandanielxk8's Avatar
Yes it has to be dropped slightly, but this is only four bolts. Not much of an issue. You can leave it hanging while you work. Also, make note of the orientation of the bolts for the lower control arm. On some years, these are eccentric bolts and affect camber, so make sure to place a mark to try to keep the alignment as close as possible to what it was.
Old Apr 23, 2023 | 02:16 PM
michaelh's Avatar
I managed by just removing the larger diameter circlip from the bellows and sliding it out of the way with the steering on full lock.
Only downside is that the circlip is a one-time use.
Old Apr 24, 2023 | 03:37 AM
Redjags's Avatar
I recently did all my front suspension components and I managed to remove the bolts by disconnecting the tie rod ends and manipulating them past the boots. As long as they're in good condition and not completely covered in rust and grime, it's an easier option, I think?
pcolapacker
Jan 18, 2022 02:40 AM
worzella
Jan 15, 2021 04:48 PM
giandanielxk8
Feb 4, 2019 09:30 AM
Higgins
Jan 16, 2019 08:19 AM
Jandreu
Jun 28, 2014 05:32 PM
