Steering rack bushes?
Old Feb 4, 2019 | 08:07 AM
giandanielxk8's Avatar
Default Steering rack bushes?
I've decided to next work on the lower control arm bushes, lower control arm ball joints and the tie rod ends. I was thinking about tackling the steering rack bushes as well, but I can't seem to find instructions on changing those.
Do they require dropping the entire steering rack? What's the procedure? How difficult are they to change?
Old Feb 4, 2019 | 08:46 AM
80sRule's Avatar
You can jack up the car to confirm, but I recall it being disconnect the outer tie rod ends, then 4 bolts and then it hangs on the steering column and you can move it plenty and slip off the old and on the new parts. Very easy.
Old Feb 4, 2019 | 08:55 AM
Oh that sounds fortuitous because it seems it would make it easier to remove the lower control arms, which is in my to do list. Am I mistaken?
Old Feb 4, 2019 | 09:30 AM
rothwell's Avatar
I did it a while back. Not hard at all. Covered here in my working thread.
Don B
XJ40 ( XJ81 )
17
Oct 23, 2025 08:39 AM
Japthug
Aug 17, 2019 11:55 AM
Don B
Jan 13, 2015 08:03 AM
AL NZ
Aug 22, 2013 06:40 PM
chupacabra
Jul 16, 2010 04:53 AM
