Lower steering column rattle
Old Nov 15, 2021 | 06:40 AM
keilwarm79's Avatar
Default Lower steering column rattle
When I bought my 2000 XKR last year it showed problems described in the TSB 211-06 (211-06 (jagrepair.com)) - steering knock due to the old version of the lower steering column (the problem was also discussed in this thread XJR loose steering and front end clunk - Jaguar Forums - Jaguar Enthusiasts Forum), which can be solved by installing the updated version MJE 9503AC. Since Jaguar does not produce that part anymore, I first bought a used one (which than later turned out it was damaged and not usable), but later I was able to source an old new stock part in an online shop. I had the new part installed at a Jaugar dealership. After installing the part the steering knock was gone. After a while I noticed another rattle in the steering wheel (when driving over uneven roads or potholes). First I thought it was something loose in the airbag (like a wire rattling against the housing). After removing the airbag the rattle was still not gone - and then I figured out what was the cause - it comes from the joint of lower steering column, which I naturally did not suspect as it is practically new (the car ran for approximately 1500 km after it was changed).
Here are two videos (
) of the rattle - it comes from the joint in the lower steering column, but only when the steering wheel is in neutral position and by moving the it fast in both directions (when I make a whole turn with the steering wheel and try to move it in the same manner, the sound does not occur). Interestingly it only takes to press the joint of the steering column while turning the steering wheel with a finger (with relatively low force) and the sound is gone. During driving, the rattle does not occur while turning the steering wheel, but only while driving straight over bad roads and potholes.
I wonder if it is possible that the dealership made something wrong while installing the new lower steering column? Or maybe damaged it during the installation?
I would be grateful for your thoughts on the topic.
Best regards
Marko
Old Nov 15, 2021 | 08:07 AM
cjd777's Avatar
I would try tightening up the nut on the spline of both sides.
Any force on the spline would take up a little slack, if loose.
Old Nov 16, 2021 | 01:41 AM
keilwarm79's Avatar
Thanks - will definitely try that out.
Old Nov 16, 2021 | 08:49 AM
dfbender's Avatar
Here are two videos (https://youtu.be/lKjVID342TM https://youtu.be/FRxR0ycs5ps) of the rattle - it comes from the joint in the lower steering column, but only when the steering wheel is in neutral position and by moving the it fast in both directions (when I make a whole turn with the steering wheel and try to move it in the same manner, the sound does not occur). Interestingly it only takes to press the joint of the steering column while turning the steering wheel with a finger (with relatively low force) and the sound is gone. During driving, the rattle does not occur while turning the steering wheel, but only while driving straight over bad roads and potholes.
Best regards
Marko
I’d take it back to the dealer and have them fix their work.
Old Nov 16, 2021 | 11:06 AM
keilwarm79's Avatar
Hello, my plan is definitely to do that. But since the dealership did not sell me the part I can imagine what their explanation will be. Therefore I am trying to get some DIY experience/opinions to be better prepared for the discussion with them
Old Nov 16, 2021 | 03:08 PM
JayJagJay's Avatar
It might be a little more complicated than it seems, there's a lot going on in there. It's a nightmare on the XJS. Not the same joint exactly but a very similar problem.
What I read (I think) in this thread is that there are some interchangeable parts between jag models. I think you want to look around post 13...
Old Nov 17, 2021 | 08:02 AM
keilwarm79's Avatar
Thanks for the input. However I think that I figured out the correct part numbers for the lower steering column - at least how I read the TSB 211-06. It should be as follows:
XK MJE 9503AB (old design, rod in rod) was changed to MJE 9503AC (new design with splines and rubber in the coupling). The TSB is about replacing the old part with the new one if there is a knock in the steering (which I was experiencing before changing the part)
XJ MNE 9501AC was changed to MNE 9501AD
On pictures the new XK an XJ parts look the same but I figure they must be somehow different if they have different part numbers.
When I was looking for the new type of the steering column, I was able to find a new part (which had also the part number MJE 9503AC on a sticker) so I am pretty sure, that I supplied the dealer with the correct part. I just hope it was somehow not installed correctly, my fear is however it could have been damaged somehow during the instalation.
fwilder
Jan 20, 2012 09:56 PM
2000CAXK8
Jan 9, 2011 03:28 AM
sempaipaul
Feb 2, 2007 09:30 PM
