weisberg
close
- Join DateJun 2012
- LocationDenver, CO, USA
Liked:61 Times in 53 Posts
For real handling improvements on curvy canyon roads, what would be more effective?
Lowering springs (from _____?)
OR
the larger rear anti-roll bar + the front and rear lower frame braces from UltraRacing (available from Throwdown Performance with free shipping)
OR
weisberg
close
- Join DateJun 2012
Whose springs did you go with?
Whose shims did you use to correct the alignment?
How long have you lived with all this yourself?
JgaXkr
close
- Join DateMar 2008
- LocationBoston Mass
Liked:285 Times in 221 Posts
I have Arden springs all around. The only shimming involved the rear camber & we used factory shims. I have had the springs for about 6 years as well as the poly bushings, the Ultra Racing braces have been on about 2 years.Originally Posted by weisberg
Whose springs did you go with?Whose shims did you use to correct the alignment?
JgaXkr,
How much difference did the Ultra Braces make? Did you get all three(3) or what? I am familiar with top brace when it comes to a front wheel drive but that is about it.
I measure rear anti roll bar at 19 mm on my car(2006 XK8). The Ultra roll bar is showing 20 mm. I am wondering if you know what your rear roll bar measured initially. This seems to be info not floating around handily. I wonder about changing this piece out.
Mike
Mike
JgaXkr
close
- Join DateMar 2008
Mike
I think the rear sway bar is smaller than that. If I remember correctly the rear bar is smaller on the coupe as well. I can measure my old one as it is sitting on the floor at the shop. My car is an XKR so the top brace would not fit my car but I still think it makes a small difference.Originally Posted by 69jag06
JgaXkr,How much difference did the Ultra Braces make? Did you get all three(3) or what? I am familiar with top brace when it comes to a front wheel drive but that is about it.
Mike
