Lukus Oil Treatment additive????
Old Jan 29, 2010 | 07:34 PM
brgjag's Avatar
Default Lukus Oil Treatment additive????
Is it worth using in any car much less my 97 XK8 I run Mobil One Syn oil in? Dude at the chain parts store said it will add more coating to parts for cold starts then any oil?
He says for a oil burning car is will go a long way to help stop the oil burning barring you don't have a MAJOR issue that only a repair can fix but said for work valve seats and rings it can help build a barrier to slow down the burning? My Jag does not burn but my other car, 96 Tbird with the 4.6 motor burns oil, hell most 4.6 FERD motor does once they get 90k or so on them.
Old Jan 30, 2010 | 08:36 AM
test point's Avatar
Despite the vast array of oil additives on parts stores shelves you probably will not find anyone in the automotive manufacturing industry that will recommend them. If anyone really developed a magic additive it would, most likely, get absorbed into the major oil industry's products.
I converted to synthetic oil many years ago and compensated by extending the change interval. My personal research and oil testing labs reports would appear to support that approach.
The last time I used an oil additive was 'Motor Honey' in a '56 Chevy to quite the valve lifters.
Everyone has a personal opinion on oil.
Old Jan 30, 2010 | 09:22 AM
brgjag's Avatar
well I bought some and going to put it in my 96 Tbird that burns off oil and see if it really works.
Old Jan 30, 2010 | 09:42 AM
Gus's Avatar
Gus
Like Tom I used it in my 55 Ford but I used STP. I did however use BG MOA in my 90 4Runner up until I sold it. I personally see no need to add it to synthetic oil but that is a personal choice and I guess it is all in what you want. Use this link for info on synthetic oils http://en.wikipedia.org/wiki/Oil_add...s_of_Additives and this for oil info http://www.bobistheoilguy.com/
I hope this helps!
Old Jan 30, 2010 | 06:45 PM
brgjag's Avatar
well i decided not to use it in my jag. but had no problem dumping it into the tbird. see if it stops the burning any. The 4.6 motor is good for eating oil.
Scarecrow
Mar 28, 2016 03:17 AM
perfectson
Nov 1, 2015 10:46 AM
buickfunnycar.com
Oct 19, 2015 07:21 PM
Tim Goz
Sep 17, 2015 09:11 AM
Gerard Radimaker
Sep 13, 2015 10:33 AM
