M113 swap to early XKR
Old Mar 14, 2022 | 07:52 AM
Vadim's Avatar
Default M113 swap to early XKR
So, my AJ26s failed, and I am considering different options. Anyone tried to put M113 into our jag?
Old Mar 14, 2022 | 10:27 AM
motorcarman's Avatar
Old Mar 14, 2022 | 01:20 PM
Vadim's Avatar
No, lol. I meant the mercedes 5 litre V8. It's cheap, and rather reliable. Also the XKR had the mercedes gearbox, so the only questions is that if there is anyway to make jaguar electrics work with mercedes ECU
Old Mar 14, 2022 | 02:48 PM
You could use the Valve Body/electronics from the Jaguar and it would likely be compatible with the Mercedes 722.6 fitted to the MB engine BUT.........
Getting the CAN bus to cooperate? with the MB engine?
good luck and keep us posted
Old Mar 15, 2022 | 06:46 PM
Don B's Avatar
Hi Vadim,
Welcome to the Jaguar Forums! It's great to have you with us.
Your Jaguar ECM is by Denso. and it is interconnected with the Mechatronic/TCM, ABS system, Climate Control, the audio system, etc. The Mercedes-Benz M113 DME is by Bosch. As Bob alluded, getting the systems to play well together would likely be a nightmare. Why not just find a good salvaged AJ26? It would be a great opportunity to replace the upper tensioners, valley hoses and octopus hose, A-drum, etc. You could address the typical failure points and have one of the most reliable X100s on the road.
Cheers,
Don
Old Mar 15, 2022 | 08:55 PM
xalty's Avatar
he is in russia. options for factory motors are going to be limited.
try to find a 4.2 and mix and match and stuff until it works.
Old Mar 19, 2022 | 07:54 AM
Vadim's Avatar
I thought about 4.2. Anyone tried to swap 4.2 in 4.0 car?
I have found aj27, I think it’s a viable option in my case. Why exactly 4.2 is better than 4.0? I thought that the difference is only in the capacity
Old Mar 19, 2022 | 07:56 AM
Vadim's Avatar
But I’m thinking about M113 and ls1 because it is the third AJ26 that failed in this car
Old Mar 19, 2022 | 09:34 AM
xalty's Avatar
did you lose compression? only way to deal with garbage gasoline is to go with late aj27 block or later.
yes 4.2 has been done many times, easiest if your heads are salvageable. sc version has aluminum “forged” pistons
rscultho
Sep 28, 2020 11:11 AM
powerhouse
Aug 14, 2014 05:56 AM
