Max ok coolant temp? Danger temp?
Old Feb 3, 2015 | 11:03 PM
Ophitoxaemia's Avatar
Default Max ok coolant temp? Danger temp?
I have a system for my 2000 XK8 Coupe that allows setting alarms for configurable thresholds on various ODBII readings.
I've had two coolant related fixes recently, water pump and leaking thermostat housing, and decided I needed to monitor the coolant temp more carefully than I have been while testing coolant-related fixes.
So my question is, what temperature should I set an alarm at?
Bonus question: are there any other readings I should set alarms for?
Thanks!
"You know you drive Jaguar when... you are compelled to wash a car you cannot drive."
Old Feb 4, 2015 | 05:45 AM
RJ237's Avatar
I have never seen a temp. over 210 deg. so I set the alarm to 220.
Old Feb 4, 2015 | 07:24 AM
ccfulton's Avatar
Highest I have seen was 215 on a very hot Arizona day while stopped in traffic.
Old Feb 4, 2015 | 11:12 AM
Great info, thanks!
Old Feb 4, 2015 | 11:22 PM
Jag#4's Avatar
+1
100F outside while stuck in traffic. The blue cat hit 215F. Fans went on high speed immediately.
workworkwork
Oct 23, 2015 10:26 AM
MrWhite
33
Oct 22, 2015 10:29 AM
vwbusbits
Oct 13, 2015 03:43 AM
baskervillema
Oct 1, 2015 06:43 PM
