Misfire codes what else can I try?
#5 cylinder misfire codes. (53k miles)
I replaced the coil pack first and no difference.
Just replaced the plug and a different new coil, perhaps an improvement but can still feel a slight misfire. I cleared the codes but no doubt they’ll be back! Couldn’t see any visual wiring issues or arcing. Anything else I can check before giving in?
Just to put my mind at rest is it normal (it happened on both occasions when I switched out the coils) the coil body doesn’t push all the way flush it kinda bounces back a bit then sits flush when the screws are tightened down. I can push it flush but I don’t feel a click like the metal cap on the plug wires back in the day....
thanks
Alan
thanks
Alan
Alan, you have done what we all would do, so I'm going to say, do a compression test on that cylinder and the one on each side, if not a end one.
May be a burnt valve is what I'm thinking.
Keep us informed.
Keep us informed.
Ok thanks, that’s a bit above my pay grade. Will have to hand it over to the pros now.
Car is only worth about $6k so not gonna spend a bunch to repair it. When smog time rolls around will probably let it go for parts.
my last xk the chain snapped at 60k so I was acutely aware of that. Luckily (if ur an optimist) it was at startup in a parking lot so “only” cost me $3k for the chain and parts to be done.
Norri
19
Sep 28, 2015 08:43 AM
