Missfire on 1 to 8
Old Mar 28, 2015 | 05:13 AM
sheddist's Avatar
Default Missfire on 1 to 8
2000 XK8
Car starts and drives gently OK, but enthusiastic driving or a steady drag when hot can result in a"rumbling" and sometimes RP. Pending codes are misfires on all cylinders and 1316- which is what flagged RP. Don't think it is coils as when it goes-it goes, it is after a good bit of throttle, it refuses a repeat performance.
Thinking it is fuel starvation, the filter has done no more than 4K miles and I am starting to think it is the fuel pump either losing performance or the mesh filter is blocked.
Have a full tank so while that is consumed, will clean the MAF, check for leaks, clean the connectors etc. Also, will go for a drive with he OBD2 connected to see what the fuel trims are up to.
Old Mar 28, 2015 | 05:37 AM
I'd suspect fuel pump or air leak too.
Old Mar 28, 2015 | 07:22 AM
jamdmyers's Avatar
Graham I'll say it for you!
Did you read any obdII codes to help us here. I know you will post but I find it hard to believe
it's running rough / RP and not have a CEL on
Old Mar 28, 2015 | 11:47 AM
JagV8's Avatar
Fuel trims will show whether an air leak or not.
Old Mar 28, 2015 | 11:51 AM
sheddist's Avatar
Flagged up missfire codes for all 8, and IIRC 1316, whih is what caused RP. Done around 60 steady miles today and not missed a beat, did not give it much stick though. Idle is fine.
Jagged-X
Sep 24, 2015 05:08 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
promoterdan
May 27, 2015 03:02 AM
rocket
May 29, 2012 07:46 PM
newboy
Jan 24, 2011 09:08 AM
