Motorola 8700 Factory phone
Old Dec 29, 2022 | 05:04 PM
Etechracing's Avatar
Question Motorola 8700 Factory phone
Hi
I am trying to get the phone to work and hope some of you have experience.
The Phone works outside the car, coonects to network and can receive and make calls.
In the car you get sound, so pressing a button on the phone will sound in the stereo. but none of the buttons are functional, it says handset in the stereo display, if I turn on the radio and press the phone button it shortly shows phone and then goes to handset.
what is it I am missing here?
Old Dec 29, 2022 | 05:07 PM
It seems to be stuck in handset mode, can it be the switch in the craddle? or is it a setting in the phone
Old Dec 29, 2022 | 05:44 PM
michaelh's Avatar
Is it a Jaguar-branded 8700 (Jaguar motif on the inside of the flip, or LNC7311AB under the battery)?
Old Dec 30, 2022 | 01:26 AM
Yes it is branded Jaguar both in the display when turned on and on the flip. however it is BB in the end not AB
Old Dec 30, 2022 | 02:37 AM
dibbit's Avatar
There should be a setting in the phone. Have you got Jaguar's manual for the phone? If not, here is the link.
http://www.mediafire.com/file/fwcty6lrqh6f01c/file
You might also need to find Motorola's manual for the phone itself.
However, apart from the novelty value, I remember those phones as being crap - a bluetooth upgrade to work with your own phone is way better.
Old Dec 30, 2022 | 02:40 AM
Yes, but cannot find anyone making a bluetooth integration that works with steering/radio buttons and display on radio.. I want to keep all original and functional. I will check the manual, have both, but settings seems to be ok
Old Dec 30, 2022 | 06:25 AM
michaelh's Avatar
There should be a magnetic strip underneath, and attached to, the cradle close to where the connector plugs in at the base of the phone.
You could try moving a magnet around the plug area to see if that switches the phone's mode.
Countriboi03
Jul 30, 2013 11:23 AM
UKnFor-dluv-expat
Nov 16, 2012 09:01 AM
mphy98
Jan 16, 2011 08:15 PM
shaynes
Mar 2, 2010 03:05 PM
CarSmartNot
Dec 30, 2009 07:50 AM
