Mr
Old Dec 7, 2025 | 01:26 AM
wallypara's Avatar
Default Mr
I have just got hold of a 2002 jaguar XK8 convertible with genuine 17000 on the clock completely rust free.
the car is like a new car. Before I drive it I have put on a new battery. four new tyres. Engine oil and filter changed. Air filter and new double iridium spark plugs.
the spark plugs I took out were original jaguar and showed signs that the car had hardly been used. Coupled with the crystal clear engine oil I took out.
the car drives like a new car with silky gear shift.
Should I change gearbox oil because of age bearing in mind it offers no problem.
I do not really want the car and will just garage it.
peter
Old Dec 7, 2025 | 01:55 AM
Pistnbroke's Avatar
These cars do not do well just left parked up . fuel pump fails and what about the battery ?
PS do a more informative title next time or you do look like a wally
Old Dec 7, 2025 | 04:39 AM
RichardS's Avatar
Gearbox will be fine with the existing fluid. I would suggest that you change it in another 50k miles but it doesn't sounds as if it's going to see that mileage.
Richard
Old Dec 7, 2025 | 06:02 AM
Pistnbroke's Avatar
The gearbox will be fine if its full of fluid ...but how do you know until you check? same goes for the back axle...
Old Dec 7, 2025 | 08:38 AM
motorcarman's Avatar
Info for you.
From the ZF5HP24 repair manual.
File Type: pdf
Old Dec 7, 2025 | 01:32 PM
michaelh's Avatar
Sounds like you've made a good find.
IMO, change all fluids - brake fluid, coolant and those already mentioned. You then have set a baseline for future periodic maintenance.
Plugs on the XK8 are good for 100K according to Jaguar's schedule of maintenance.
I imagine that a few drives will change your mind about not really wanting it
Old Dec 7, 2025 | 03:34 PM
Pistnbroke's Avatar
Press the sport button for a real ride ...Normally it starts in second but with the sport button down its starts in first for a rocket mode ...then you will love it ....
Old Dec 8, 2025 | 07:44 PM
MVMonarch's Avatar
Low mileage can be a blessing and a curse. Most running parts will be like new, but extended periods without driving comes with its own set of issues, like why the car remained parked so long. Could be a collector’s car or from the estate of a long-deceased owner. Keep your checkbook handy. Good luck!
Dave K
Jan 10, 2015 02:29 PM
arath25
Sep 1, 2014 07:23 AM
Jon89
Mar 8, 2011 10:18 AM
hm1
Aug 25, 2010 11:50 AM
FloridaJag
Jun 28, 2009 09:16 PM
