multiple check engine lights
Old Apr 30, 2013 | 08:07 PM
nine7xk8's Avatar
Default multiple check engine lights
I put a new transmission in my jag. and took the engine out to do a full complete timing chain change. I made a mistake and had this shop put the stuff back together now im having all kinds of codes. codes for egr and the car never had one. one of the vacuum lines have a bolt in it and i think it is suppose to connect to the eval purge. camshaft sensor code, throttle position sensor code. man this is a headache. It seems no body can figure this out.
Old Apr 30, 2013 | 08:17 PM
nine7xk8's Avatar
the codes are p0223 p0340 p0405 p1229 p1336 p0121
Old May 1, 2013 | 01:33 AM
H20boy's Avatar
You're going to have to get your schematics and drawings out and recheck every vacuum line and intake hose. Obviously one was left unconnected, but others could be mixed up as well. The plastic rigid lines are usually bent a specific way and never the same length as another, but I've seen worse debotchery. Start with the EGR system first, obviously.
BrentGardner
29
Dec 16, 2024 12:13 AM
kurtomatic
Feb 12, 2024 06:58 AM
big d
Sep 3, 2015 07:37 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
