Mystery (?) Connector
Old Feb 12, 2016 | 04:54 PM
scardini1's Avatar
Default Mystery (?) Connector
While prowling around the back of the engine chasing down my P0171 nemesis, I stumbled upon a loose connector. At first I thought I had knocked it loose, which is scary when you can't find the other end! It's a two wire, female connector with black & Red/white wires.
My schematic shows something called an "Ignition Coil Relay" that was installed on earlier cars. It's the only thing I can find with those color wires. Did they leave that pig-tail and connector in cars that no longer had that relay? Here are some pics:
BTW: For those of you with Super Chargers, there is a 2 inch vacuum hose that goes from the throttle body elbow (base) to the Bypass Actuator at the left rear of the engine. Mine was a thin walled, fairly stiff tube, which was almost completely collapsed. I replaced it with more routine rubber vacuum hose.
Attached Thumbnails Mystery (?) Connector-kitty-connector.jpg   Mystery (?) Connector-kitty-connector-2.jpg
Old Feb 12, 2016 | 06:32 PM
woox4's Avatar
It is not used on mine and is just taped out of the way.
Old Feb 12, 2016 | 07:44 PM
scardini1's Avatar
Perfect. That confirms it. Thanks Chris!
VR6Guru
US Western
Feb 22, 2021 02:39 PM
adenshillito
Apr 17, 2016 02:49 AM
MrWest
Feb 27, 2016 01:54 PM
Qgregg
Feb 11, 2016 09:23 PM
TexMurphy
Feb 11, 2016 07:13 PM
