Navi to Garmin
Old Oct 31, 2024 | 08:22 PM
KC XK8's Avatar
Default Navi to Garmin
There is one video out there from 2014, but are there any newer videos or photos on the wiring once you get the old navi out?
Thanks.
Old Nov 1, 2024 | 03:41 AM
dibbit's Avatar
You can find the connections in the electrical guide for your car. Ignition switched 12v and ground are in the harness that goes/went to the OEM sat nav:-
There is no need to get the supply from the glovebox, which some videos show.
On the smaller of the two connectors:-
32I white/blue is the ignition switched 12v
63 brown/red is the permanent 12v
Black is the ground connection
You also have the dimmer supply red/blue if you want to put the buttons back in and connect up the backlights like I did.
Double check on the wiring diagram for your year car.
Old Nov 2, 2024 | 10:34 AM
Xman's Avatar
Very good info! I'm debating wether to replace existing "old" navi with a new option (Garmin model and/or other option) OR go with the 3-gauge look-although the challenge seems to be finding a really close color match replacement in walnut burl wood for the mid panel with a similar looking 3-gauge one. I do like the 3-gauge look overall.
The current option that I'm using is not to change/use the navi and just utilize my samsung flip phone with magnets in holding it to the dash for a very clean/easy mount use as my vehicle is a weekend fun car. Although it would be beneficial to have a better viewable navi screen when needed especially in direct sunlight Anyway, good luck with your project.
Old Nov 2, 2024 | 11:20 AM
KC XK8's Avatar
my Garmin 66 is too big. I’m trying to source a 55. The picture shows that the screen is just too large.
Jan 25, 2021 02:50 PM
Ubad2
Sep 21, 2016 12:38 PM
powerhouse
Jul 26, 2015 10:46 PM
gragner66
Photography
Jul 7, 2013 08:57 AM
DrScientist
May 17, 2012 10:22 AM
