need someone to confirm operation of telescoping steering wheel
Old Jun 16, 2025 | 10:03 PM
stevepaa's Avatar
Default need someone to confirm operation of telescoping steering wheel
So my cable broke that works the extension of my steering wheel. But with the motor off but still electrically connected I can use the toggle switch to power the motor. The motor will run for about 4 sec then stop, if I push the toggle again in same direction the motor will run again for 4 sec. I am not clear if that is proper operation..
Can someone explain it?
Old Jun 18, 2025 | 07:35 AM
dibbit's Avatar
On my car it takes about 4 seconds for the wheel to telescope from fully in to fully out and vice versa. It wouldn't surprise me if the electronics always cut the power after 4 seconds as a safety precaution, or it is timing out because the computer can't see any movement of the wheel, despite the motor turning.
dnati
Feb 15, 2020 11:31 AM
Johnken
Jun 17, 2015 05:08 PM
Johnken
Jun 5, 2015 06:02 PM
Johnken
Apr 12, 2015 05:18 PM
sempire
May 29, 2011 11:05 AM
