Need Variable Valve Timing Seal
Old Sep 8, 2010 | 08:07 PM
kdross's Avatar
Default Need Variable Valve Timing Seal
I am in the process of rebuilding the engine of my 2000 XK8. The prior owner never changed the oil and the oil turned into sludge (only 43K miles). The seals on what I believe are the variable valve timing hub are bad. There is one seal on each side (right and left). I called the dealer and was told this was a "life time" part and that you cannot purchase the seal. They want sell me the entire assembly for $500 per side. This is probably a $2 part and someone has to sell the seal (it looks more like an o ring or a collar). Does anyone have any advice on where I can purchase this seal or what the part number is? This is the hold up on my rebuild and I am trying to complete the rebuild in time to enjoy the September weather and use my car with the top down.
Old Sep 8, 2010 | 08:31 PM
mike66's Avatar
Try Continental Imports in CA. They helped me out when I needed an oil control solenoid for the VVT. Phone #(510) 532-6603. No current Web site. Hopefully get you a seal or a good used part.
Mike
Old Sep 8, 2010 | 08:42 PM
motorcarman's Avatar
Without knowing exactly which seals you are looking at, I will guess at
part # NNE2622BA. These seals are fibre split rings that seal the actuator to the VVT unit on the intake cam. Call the dealer and get the JEPC part description for 'XK8 COUPE/CONVERTIBLE FROM (V)A00083 TO (V) A30644/ENGINE/TIMING CHAINS AND ADJUSTERS/TIMING CHAIN-SECONDARY-4.O LITRE-V8' and look at the exploded view for the part. You should be able to pick the part from the diagram. you could also ask them to look up the part # and look at the diagram to see if it is the part you need.
bob gauff
Sprayall
May 30, 2021 08:13 AM
PMKimpton
Aug 3, 2019 08:22 PM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
