Need wheel for 2001 Jaguar
Old Mar 29, 2012 | 06:30 PM
Markarras's Avatar
Default Need wheel for 2001 Jaguar
Got new tires the other day and found out my wheel was bent, went to the dearlership and was informed they don't stock them anymore...any idea's as to where I can get a replacement. They were the chrome option rims for the 2001 XK-8.
Attached a pic of car hope that helps and as always thanks much
Mark
Old Mar 29, 2012 | 06:48 PM
billm's Avatar
Try the usual places - E Bay and Craigs List (though Craigs List is always a little scary). Additionaly, there are some Vendor Firms on the Forum that also can probably help.
Old Mar 29, 2012 | 06:51 PM
Too far away from you to make any useful suggestions on where to obtain a replacement but may be able to help with identifying the rims.
That looks like either Impellar or Hydra rims but difficult to be certain from the thumbnail image.
You'll also need to check rim size required. My 2001 was on Impellar rims with 8.5 x 18 Front and 9 x 18 Rear.
Old Mar 29, 2012 | 07:41 PM
WhiteXKR's Avatar
Mark
There are shops that do bent rim repair. You can surely find one locally, or use these guys who have a good reputation: Wheel Collision Center Bath PA- Excellence in Refinished/Used Factory OEM Aluminum Alloy Wheel Rim Sales & Alloy Wheel Rim Straightening Repair Refinishing & Recycling! - www.oemfactoryrimwheel.com Excellence in Refinished/Used Factory OEM Aluminum A
Old Mar 29, 2012 | 07:47 PM
Skid Mark's Avatar
Those are Impellers. Have you looked around your area to see if there's somewhere you can get the wheel professionally trued or repaired? They can take out some pretty bad bends, and probably would be quite a bit less that buying and shipping another used one that could have issues of its own. Ask around the car dealer body shops, they use those wheel repair guys quite a bit.
Old Mar 29, 2012 | 07:48 PM
Kevin D's Avatar
Smile
OK, my first venture onto this forum was the same question that you have.
I got no replies whatsoever. The forum is a little more friendly now. That is why I will give you a response.
I spent a couple of months trying to find a wheel, and simply could not. What I was told was that since the front wheels are 8 inches and the rears are 9 inches and that the front wheels are far more likely to be damaged than the rear wheels, that the front wheels were very hard to find. I was also told that the typical Jaguar owner was more likely to keep the original wheels as opposed to some other car owners so that that fact reduced the number of original wheels available. After almost three months of looking, and being unable to find a wheel I was referred to a wheel repair facility.
In the end, I was able to have my wheel repaired. (it had what they called pothole dings)
If I were you, I would try to see if the wheel is repairable. If not, then, I wish you better luck than I had.
Old Mar 29, 2012 | 10:02 PM
jabingb's Avatar
Mark
Try these guys, not sure about chrome but they have your rim listed...
2001 Jaguar XK8 Rims, 2001 Jaguar XK8 Wheels at OriginalWheels.com
Old Mar 30, 2012 | 07:42 AM
berlin1977's Avatar
Check my tread cracked rim. I had mine welded, it was a small crack on the inside of the back rim. One company that I had asked the members about was rim guard extreme. They gave me a cost of $175. Shipped UPS. Check the web page of the rims that they have repaired they are amazing. Hope it helps. Jim
Old Mar 30, 2012 | 05:48 PM
Markarras's Avatar
Thanks for all your help, looked on Google and not much there. I do have someone my local Jag dealer recommended guess I'll go that route....Thanks everyone
Old Mar 30, 2012 | 06:10 PM
OhioXK's Avatar
it says out of stock but try giving them a call:
2001-2003 Jaguar XK-8 Impeller 7 Split Spoke chrome plated wheel. Hollander number: 59715 front and 59716 rear
tonimccloud
19
Jan 18, 2020 01:56 PM
Griffbritgreen
Jul 27, 2016 05:43 AM
celticpiping
Sep 18, 2015 06:17 PM
dpappyp
Aug 27, 2015 06:31 AM
souldoubt
Aug 25, 2015 08:15 PM
