Never an issue then boom, engine won't turn over
Old Nov 15, 2013 | 10:24 PM
DeanoDD's Avatar
Default Never an issue then boom, engine won't turn over
Just took delivery of my 03 XK8 (37k) from TX to OH 2 months ago. I have been starting and driving with zero issues once or twice a week before I put up for winter. I start it up today (after a couple weeks) and drive a few miles to a friends house and a couple minutes later go to start it up and nothing but a click under hood. Everything boots up OK, steering wheel assumes position etc but starter will not engage...just a click under hood. I tried numerous times within 5 minutes to start to no avail. I shut all current draws down, radio, blower, etc and waited a few minutes and it started right up.
Not sure how old the battery is (looks to have been in there awhile) but could a failing intermittent cell in the battery cause this behavior?
Any thoughts much appreciated
Old Nov 15, 2013 | 10:27 PM
I'd start with the battery, get it checked and go from there.
Old Nov 15, 2013 | 11:16 PM
Steve8's Avatar
Yep, battery is first thing to check. If it looks old, it probably is old. You'll be driving again in no time.
Old Nov 19, 2013 | 10:22 AM
Burdedw's Avatar
I had a similar problem on this past Sunday, but I lost all electrical power to everything.
I wiggled the cable ends on the battery to get home, then cleaned the Battery Terminals and Cable Ends.
Problem solved!
If the battery checks out good, it may just be a bad connection at the battery or maybe at the starter.
BrentGardner
29
Dec 16, 2024 12:13 AM
NTL1991
XJ40 ( XJ81 )
Sep 24, 2015 09:09 PM
JakeJagg11
Sep 3, 2015 07:36 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
