new engine number
Old Nov 12, 2020 | 04:09 PM
jacopost's Avatar
Default new engine number
Hi,
I'm restoring my 1999 Coupe imported from UK and preparing the documents to register the car in Italy where I live.
trying to read the engine number I've found it underneath on a rib, not close to thermostat tower.
The number seems for a 2003's unit and there is also a NNGNO punched close to the number.
May this stand for new engine number?
If my engine was built in 2003 the chain tansioners are of the new metal type correct?
The mileage on the tachometer starts from the engine replacement?
Old Nov 12, 2020 | 05:53 PM
That numbers on the left looks like the OE cylinder bore and piston codes:
The numbers on the right don't look like Jaguar applied ones.
Old Nov 12, 2020 | 06:55 PM
michaelh's Avatar
Odd. If the engine # really is 030605 1621, doesn't that imply a 4.2L?
Location and format looks OK - see this post from GGG:
https://www.jaguarforums.com/forum/x...2/#post1949371
The engine number on a '99 should be at the side of the thermostat housing as shown in this post, also from GGG:
https://www.jaguarforums.com/forum/x...2/#post1948910
Can you see anything there?
Last edited by michaelh; Nov 12, 2020 at 07:29 PM. Reason: add earlier 4.0 # location
Old Nov 13, 2020 | 12:06 AM
jacopost's Avatar
the number in the pic is on the left side of the engine
nothing near the thermostat housing
Old Nov 13, 2020 | 07:17 AM
PKWise's Avatar
jacopost,
Agree with michaelh, your engine number is a 4.2L engine.
See image of mine which is a 2003 XKR 4.2, but my engine number pre-dates yours!!
Old Nov 13, 2020 | 10:41 AM
jacopost's Avatar
fantastic! good news
Old Nov 13, 2020 | 04:39 PM
michaelh's Avatar
Interesting. I wonder if the car has had something similar to this done:
https://www.xk8-parts.com/2017/01/ja...ne-conversion/
or this from smoggyx100:
https://www.jaguarforums.com/forum/x...5/#post1772265
Not for the faint-hearted
Old Nov 14, 2020 | 01:13 PM
xalty's Avatar
the 4.2 swap and all the labor wasn’t very expensive in the UK, there were a couple shops that know how to do it
Old Nov 14, 2020 | 01:18 PM
jacopost's Avatar
i wonder if it has been changed to have better performances or due to an issue.
the v5c reports the original engine number, built in 1998
dedwards
Sep 24, 2020 09:54 AM
mu2rick
E type ( XK-E )
Mar 26, 2018 09:24 AM
xj-c4.2
Apr 13, 2017 11:44 AM
Gippsland
Apr 15, 2013 05:11 AM
GreenJewel
May 13, 2009 03:00 AM
