New Member
Old Mar 16, 2018 | 09:56 AM
rsdmitch7's Avatar
Default New Member
Hello; Where is the best place to find out if my '99 XK8 4.0 vin#SAJGX2043XC032833 has plastic or metal timing chain guides and tensioners? It's just turning 80,000mi. Am I correct in thinking this should be done before 100,000mi
Mitch
Old Mar 16, 2018 | 01:03 PM
Mitch,
I've moved your question from US Northeast Region to XK8/XKR forum.
The model forum is the best place to post technical questions and members here with the same model will be able to help.
Old Mar 16, 2018 | 01:19 PM
rsdmitch7's Avatar
Thank You much. Still trying to get a handle on the program
MItch
Old Mar 16, 2018 | 01:39 PM
fmertz's Avatar
Mitch
I hate to be that guy, but you need to pull the valve covers and check ASAP. When these secondary tensioners fail, the cost of the replacement engine parts rival the value of the entire car. These are so problematic, you should probably park the car until you find out for sure.
Old Mar 16, 2018 | 01:41 PM
Fulton's Avatar
You have the 1st generation plastic ones. Mine were ready to fail at 50,000m
if you don't have proof yours were changed, better check. That means removing the valve covers.
Old Mar 16, 2018 | 01:42 PM
rsdmitch7's Avatar
Thanks fmertz. I have the car down now. I just thought there was an easier way than pulling the valve cover.
Mitch
Old Mar 16, 2018 | 02:24 PM
rsdmitch7's Avatar
Default Thanks from Mitch
Thank you Fulton. I will need to start assembling the parts. Any suggestions where to buy from
Old Mar 16, 2018 | 03:38 PM
StuG's Avatar
"I will need to start assembling the parts. Any suggestions where to buy from"
Lots of previous posts regarding tensioners. Do a search.
https://www.jaguarforums.com/forum/x...nt-kit-189047/
Stu
Old Mar 17, 2018 | 08:01 AM
rsdmitch7's Avatar
Thanks Stu much appreciated.
Mitch
Old Mar 21, 2018 | 06:35 AM
Fulton's Avatar
SNGBarratt.com is my default vendor. Ask for the forum discount.
Old Mar 21, 2018 | 10:54 AM
rsdmitch7's Avatar
Fulton;
That's great to know. Again thanks very much
Mitch
hinckley
May 10, 2023 04:51 PM
Tango Nevada
Sep 21, 2018 03:18 PM
moranlr
Feb 17, 2014 11:30 PM
Vejita88
Nov 26, 2012 04:17 AM
JaggyUK
Jan 2, 2012 02:27 PM
