newb
Old Oct 22, 2014 | 09:49 AM
Race1faster's Avatar
Default newb
hello everyone, the other day I posted some ?'s , and I am still in need of some direction 02 jag xkr conv. started with running light problem, then a mafs code p0102 , then a trac unavailable,/ restricted perf then an engine light- thats ALL
I have been checking grounds, wiring, fuses, relays and I am stumped ,rear fuse
box in rt rear luggage comp.seems to be an issue however I dont know, some of the power to fuses there seems to be acting funny I think?
Old Oct 23, 2014 | 09:37 PM
ccfulton's Avatar
Have you tried cleaning the MAF sensor?
Or checked the voltages at the MAF connector to make sure there is a good +12, +5, and ground?
On the 2002 and earlier cars the part load breather can become clogged pushing oil into the intake tube, fouling the MAF sensor. If you open the airbox is there oil on the air filter?
Old Oct 25, 2014 | 01:13 PM
Syndarrin's Avatar
I'm a 3 month newbie also. don't know if it will help you but I downloaded all the repair and service repair training manuals at
JagRepair.com - Jaguar Repair Information Resource
It's a lot of reading but scanning thru the books whenever I need to find what I needed was a huge help, especially the pictures and pages that show where the relays, each module and what it controls and all the myriad of fuses/boxes. The pages in one of the manuals lists each component and where it is wired and what fuse or other components it goes to along with a physical description of where and how to access it on the car. And also where the ground lugs are that grounds each item.
Martyn-R
Sep 8, 2015 03:56 PM
1FastJag
Aug 12, 2015 06:53 PM
Isaac Moller
Aug 10, 2015 10:23 AM
rawdeal
Nov 20, 2013 02:49 AM
smith_mike
Apr 13, 2009 05:08 PM
