Newbie question
Old Apr 22, 2010 | 09:17 AM
Mike79's Avatar
Default New to this forum as well.
Just bought a 2003 coupe, 55000 miles at auction for 10 grand. Great car!
Have already benfited greatly from all the expertise.
Can someone give me the link to seat module repair?
Thanks Mike
Old Apr 22, 2010 | 09:44 AM
H20boy's Avatar
Originally Posted by Mike79
Just bought a 2003 coupe...can someone give me the link to seat module repair?
Thanks Mike
Whats wrong? what repair are you referring to mike?
Old Apr 22, 2010 | 08:25 PM
Mike79's Avatar
Default seat module repair
Thanks for getting back to me. All function work except the seat back will
recline, but won't come back up. I took the module out of the drivers side
and temporarily plugged it in the passenger side and all function worked.
Looks like some one spilled something in the module and a couple of the
circuit wires look corroded.
I am thinking about looking for a computer geek that can fix the board.
Mike
Old Apr 23, 2010 | 05:13 AM
Brian2000XKR's Avatar
To Steve:
"....I would have to listen to my wife say, 'you should have gotten and SC430'."
She would be right............up to a point. I purchased a new SC430 for my wife and it has been flawless for the 5 years that we have owned it. Nice driving, perfectly reliable and classy looks. That being said, I greatly prefer to drive the Jag! The XKR feels like a race car, and reminds me of the cars that I drooled over as a kid. I know that it doesn't come close to some of the speed demons on the road, but it is plenty fast enough for me, has a incredible interior, and a drop dead gorgeous body. It may not be the best in any single category, but it scores extremely high marks in all of them. Sure, it has a few maintenance "warts", but what in life is truly perfect? I'm not, so is it reasonable of me to expect my car to be?
Good luck with your new Jag, I'm sure that you too will love it!
Regards,
Brian
Old Apr 23, 2010 | 09:17 AM
H20boy's Avatar
If you swapped the modules, and got all functions on the other side, i'd focus on the switchpack with your buttons instead of the module. Take it apart and clean all of the contacts (especially the recline), most likely the spill happened on it and you lost some button function. Check wiring from the switches to the module as well next.
Old Apr 23, 2010 | 05:31 PM
Mike79's Avatar
Default switch pack
I probably miscommunicated the problem. When I put the driver's side module on the passenger side,(the passenger side is the one that won't return the seat back) all functions on the passenger side worked fine.
Thanks, Mike
Old Apr 23, 2010 | 09:07 PM
H20boy's Avatar
Ahhh, that makes more sense. Sorry, you are correct, it sounds like a short or bad connection IN the module. Better find someone who dabbles in circuit board repairs, I hear its not that difficult...though I shy away from repairs like that all the time.
Old May 8, 2010 | 01:33 PM
  #28
attaboy's Avatar
Default "the car is capable of so much more than I am." .. me2
Originally Posted by test point
Sorry, I have to agree with Doug's plan 'B'. The XKR advantage might be significant where the roads are straight and flat but in the mountains with twisty roads the XK8 can be scary enough. You might be in a lower gear with the XK8 but either are capable of far more than curvey public roads, traction and reason should allow. Like my shooting gear, the car is capable of so much more than I am.
I chose to spend my money on the best XK8 that my budget would allow.
Echoing these sentiments ... the XK8 can really Leap .. if you forget to turn off sport mode. I'm in the mountains too ... I need an "R" like another hole in the head :-) The most fun ever with your clothes on. There is a DIY fix for the hydraulic problem .. kit is about $300 or so .. mounts on the pump .. reduces the pressure down to about 900 psi from 1,600 as I recall ... totally adequate. Less pressure, less leaks/blowout.
Steviedee1st
Nov 28, 2023 06:32 PM
redgear
Sep 18, 2015 10:05 AM
kesslari
Sep 17, 2015 08:39 AM
DustysSon
Sep 13, 2015 04:17 AM
raffoulig
Sep 8, 2015 01:56 AM
