Newbie:Restricted Performance & CEL Came On When Disabling the Antenna ?
Old Nov 16, 2009 | 04:39 PM
jagxkrtoofast's Avatar
Banned
Arrow Newbie:Restricted Performance & CEL Came On When Disabling the Antenna ?
So I called myself disabling the antenna. I checked for fuse #9 but could not find it. So I pulled a big white plug out near the antenna. I get into the car then Restricted Performance pops up. I plug it back in and then it disappears. I believe I pulled the wrong plug but anyways I searched deeper and found a little white plug that plugs into the antenna motor so I disconnected that one instead. After that the CEL came on and when I turned it off the CEL disappeared. I havent had a problem since but I just want to make sure everything is fine ?
I pulled the white one near the antenna in the trunk
Old Nov 16, 2009 | 04:45 PM
brgjag's Avatar
The Antenna tells the computer the WIND SPEED of the car when in motion, if disconnected it will throw those codes.
Old Nov 16, 2009 | 05:02 PM
H20boy's Avatar
The green with the black tracer is all you need to interrupt. If I were you, instead of pulling the entire plug out (obviously other functions going on there), simply put a toggle switch inbetween the black (ground) and the green/black wire.
Old Nov 16, 2009 | 05:04 PM
Banned
Ok thanks again guys.
Old Nov 16, 2009 | 05:35 PM
eaglexkr's Avatar
Smile
brgjag,
Thanks for your answer,it put a smile on my face.
Just wonering if you could keep a straight face with that answer in person?
Still Smilin'
Old Nov 17, 2009 | 02:45 AM
GreenJewel's Avatar
Hahahaha, how the heck is this going to take place if the antenna is in the lowered position??
oldjaglover
Dec 25, 2024 04:33 PM
Delta66
Oct 4, 2015 05:40 PM
Johncy2000
Oct 2, 2015 01:05 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
