Next Project - Seat Belt Locking Retractor
Old Jan 23, 2012 | 09:24 PM
Rthomas7's Avatar
Default Next Project - Seat Belt Locking Retractor
I am tackling the driver's side seat belt retractor not retracting. UGH. Downloaded the parts diagram. I saw H20Boy'spicture of the seatbelt. So I really have to remove the entire back seat? double UGH. This is turning into a much larger project.
  1. Does anyone have any tips or tricks for getting to the mechanism and repairing?
  2. Where is the best place to order parts?
Any pointers are greatly appreciated.
Old Jan 24, 2012 | 12:51 PM
H20boy's Avatar
the rear seat is only attached with two bolts under the front (footwell area) The side panels have more screws/bolts...but its very easy, nothing to worry about.
I assume convertible...
1. upper trim panel on the side (my dog likes to rest his head on this when we drive) the snap fastener for the convertible boot cover screw uses a small spanner wrench to loosen, and remove
2. remove the other screw nearby
3. upper trim panel lifts off
4. remove the cover off of the seatbelt guide bolt (just snaps on/off)
5. use a Torx bit to remove the very large seatbelt guide bolt
6. remove the 'hidden' recessed screw on the panel
7. side panel should now be able to be negotiated out from the door sill trim and give you access to your seatbelt rectractor
Also easier to remove the side panel if the lower seat cushion has been taken out already.
I did that by memory, and its been awhile, I hope I didn't forget something! If I did, someone please jump in.
Old Mar 23, 2012 | 09:20 PM
Rthomas7's Avatar
Driver's side seat belt problem is now fixed. Simple repair. Thanks for the input from h20boy...
dsnyder586
Dec 29, 2024 07:39 PM
BadKat174
May 26, 2023 12:29 AM
kevinl
Oct 31, 2019 06:15 PM
adam699
Sep 12, 2015 05:32 PM
jagent
Sep 12, 2015 09:10 AM
