No cigarette lighter
Old May 13, 2016 | 08:28 PM
Salu498's Avatar
Default No cigarette lighter
No cigarette lighter in my XK8, just the hole near shifter. Can't feel or see any wires inside. What do you think? Any way to install one?
Old May 13, 2016 | 09:28 PM
BobRoy's Avatar
Yes you can install a cigarette lighter if you want. You will have to remove the center console to do it. I just removed my cigarette lighter and installed a dual usb charger that I think looks a lot better.
Old May 14, 2016 | 06:56 AM
Scottsgreenjag's Avatar
From: Somewhere south of Grand Rapids, Michigan, USA
Nice idea! How long did it take you to install it and do you keep dummy plugs in them to prevent debris from getting in?
Old May 14, 2016 | 07:01 AM
excellent idea!!!
Old May 14, 2016 | 07:56 AM
BobRoy's Avatar
I got the idea from a member on the X308 forum that was questioning how to get the cigarette lighter out. I don't know him but our newly returned member's Reverend Sam video on how to remove the center console was extremely helpful on removing the console. I then removed the cigarette lighter. I cut the connector that plugs into the lighter and installed the connectors that come with the usb port but first adding a jump wire about 3 " long to the ground that I soldered to the light for the cup next to the lighter( it had got it ground from the lighter before). I had to use a round file to enlarge the hole slightly. I also had to file the ring that screws onto the port because clearance is thigh. Make sure you put the hot wire on the positive side because the first time I didn't see the markings on the back of the port and fried it.
Old May 14, 2016 | 08:14 AM
larueb's Avatar
I purchased a Belden charger with 2 USB ports that just slides in, a bitch to pull out as it fits tight. Not as sexy as this but just a plug and play. Now I will just leave it in.
Old May 14, 2016 | 08:40 AM
BobRoy's Avatar
When I saw the port on the X308 forum I just happened to have the console out because I was doing work on the radio. My orgional lighter had a bad connection when I plugged the adapter in. So while I was at it I killed two birds with one stone. I had trouble finding the port. When to Best Buy, Fry's, and the auto parts stores with no luck. Found it at a local car audio shop for $25 and later saw them online.
Old May 14, 2016 | 07:36 PM
Salu498's Avatar
Default Need link
Need link to Rev. Sam video on removing console so I can install cigarette lighter. Not going to use as lighter but want a complete car.
Old May 14, 2016 | 08:41 PM
BobRoy's Avatar
http://api.viglink.com/api/click?for...%20-%20YouTube
This is the link to the video but it can also be found in the how to videos on this forum
Scottsgreenjag: The usb port I got came with a cover but I didn't install it because you can close the cover on the armrest to keep things out when not in use.
Old Jul 20, 2021 | 11:23 AM
jhuertas's Avatar
Default Volt distribution across the cigarette lighter
A little late, but it can be useful
The cigarette lighter plug of the jaguar xk8 (I have recently had a 2003 model) does not accept USB chargers due to the configuration of the positive pole, which is not in the bottom and center of the plug cylinder, it is laterally and is where the positive from the lighter. That is, the central rivet is not conductive, but be careful, if there is 12V just the center that is deeper, on the side plates (where the lighter fits) and on the bottom plate (marked with a red dot).12V are indicative
Old Jul 20, 2021 | 02:34 PM
jhuertas's Avatar
Default Solved
Using sandpaper over the 0V area, the chargers work (the previous owner must have used the lighter a lot and there was insulating dirt).
It is important not to use a charger with an elongated ground connector, depending on the position, this can cause a short-circuit between the ground areas and the 12V sides.
Jacob67
Apr 20, 2019 06:17 PM
JimC64
May 21, 2016 07:37 PM
99XK8inPhx
May 14, 2016 08:15 AM
revski666
May 13, 2016 01:34 PM
realarm
May 12, 2016 09:07 AM
