No crank condition
Old May 17, 2022 | 04:25 PM
Michael MJ's Avatar
Default No crank condition
Sorry, I know this has been done to death, but I’ve read everything I can on this and am still stumped by an intermittent no crank condition. Here’s the run down:
I believe I’ve ruled out relays. I replaced the 5 associated with starter and played musical relays.
I believe I have ruled out battery which was tested at parts store and it delivers over 12.5 v.
I believe I’ve ruled out security as I’ve locked with the windows down, reached and turned ignition. The car accepted the key and no alarm.
With key in start position, I have 12v switch signal to the relay. The relay clicks (I’ve tested several) but no crank
I’ve gone underneath and jumped the starter terminal with a screwdriver and it engages and spins.
The weird thing is that across the switched terminals on the starter relay (pins 30 and 87) I have way less than 12 v. I don’t know why. Any thoughts??
Thx!
Old May 24, 2022 | 01:14 PM
XKRRANDY's Avatar
Check for 12 volts at each of your 5 fuse boxes
Randy
olivermarks
XJ XJ12 ( X305 )
41
Mar 26, 2021 05:12 PM
Rob Benjamin
Nov 7, 2020 01:27 AM
Ernest Knox
XJ40 ( XJ81 )
Jun 30, 2020 07:41 PM
julandnic
Dec 3, 2018 09:44 PM
Sarc
May 30, 2015 04:57 PM
