No instrument lighta when headlights are turned on
Old Mar 12, 2026 | 06:02 PM
Pantera928's Avatar
Default No instrument lighta when headlights are turned on
2003 XK
Whenever the car is running, there are lights to illuminate the instruments/gauges but when the headlights or parking lights are turned on, the instrument/gauge lights go out so you cannot see anything while driving at night.
Cant find any bad fuses and adjusting the dimmer rheostat does not seem to make any difference. It is wired up.
Ideas? Thanks
Old Mar 12, 2026 | 06:08 PM
giandanielxk8's Avatar
The normal behavior is that they dim when you switch on the headlights or parking lights to avoid dazzling. Perhaps the PO fitted cheap LEDs that only go on and off and do not dim. In that case, the drop in voltage to dim them when you switch on the lights may cause them not to illuminate.
Could be something else entirely, but within my knowledge of the system, that makes sense to me.
Old Mar 12, 2026 | 06:26 PM
zray's Avatar
Pertinent question: was it always like this ?
or did this issue suddenly appear ?
Z
Old Mar 12, 2026 | 07:42 PM
Pantera928's Avatar
While I wish it was that simple, that is one thing the PO did not screw up on this car. He did screw up everything he touched.
All bulbs have now been replaced and non were LEDs.
I do know that it has been this way since I have been around this car so it is nothing new that suddenly started happening.
Thanks for your ideas and questions so far
Old Mar 13, 2026 | 03:02 AM
Pistnbroke's Avatar
FIRST RULE OF AUTO ELECTRICS...
If operating one circuit causes another to go on or off its an earth fault.
So the dash lights are getting there earth via the sidelight filaments . When you turn on sidelights the dash lights get +12v to both sides so they go out ..so there you go
Old Mar 13, 2026 | 03:51 AM
dibbit's Avatar
The most likely culprit is a break in the wire from the lighting stalk to the dimmer module/dimmer override switch - electrical guide says it's a red/white wire. I would first test at the override switch and make sure the lighting stalk is grounding it when the lights are on.
BTW the dashboard lights are controlled by the dimmer module and it is quite complicated the way Jaguar did it.
Old Mar 13, 2026 | 04:48 AM
zray's Avatar
Originally Posted by dibbit
“……../$332??!44)));)@BTW the dashboard lights are controlled by the dimmer module and it is quite complicated the way Jaguar did it.
^^^^^ THIS ! ^^^^^
I can see this motto hanging over the engineering department’s door, “Make It Complicated or go home.”
Z
Old Mar 13, 2026 | 02:48 PM
Pantera928's Avatar
If it were as simple as @Pistnbroke stated, i would not be asking. I wish it was that simple though.
Second rule of electricity
If it has no voltage, it will not work.
I guess that i did not know of a dimmer control module. I think it is in the fuse box by the glove box
FYI, when the headlights or parking lights are turned on, the 12 volts on the read wires at the dimmer switch goes away.
I have the wiring diagrams for this car. I used to think Porsche diagrams were difficult until I got hold of the Jaguar ones.
Thanks for the help thus far.
Old Mar 15, 2026 | 09:22 AM
Pantera928's Avatar
Quick update.
If you turn the headlights on with the ignition off, it has dash/gauge lights but you cannot adjust the brightness. As soon as you turn the key to start the car, they go out.
Thinking dimmer module maybe ??
Old Mar 15, 2026 | 09:40 AM
dibbit's Avatar
Does the dimmer override switch do anything (try it with lights on/off and ignition on/off)? The dimmer should also control the lights on the centre console, ignition on or off - do they come on with the headlights?
If you can find a dimmer module cheap enough it would be worth swapping - worst case scenario you end up with a spare unit,
If you haven't already done so check power and grounds at the module connector with a test light and check the dimmer override with a test light (one side to +12v the other side to the override switch) - other than that it's guesswork really as to what exactly the dimmer module is supposed to be doing, so all you can do is test the inputs to it are behaving as the wiring diagram shows.
Old Mar 15, 2026 | 04:26 PM
Pantera928's Avatar
First i have heard of a "dimmer override switch". Is this something different from the brightness adjustment knob? If so, where is it located?
Grounds and power have been checked to a degree with a DVM.
I can pull a dimmer module out of another car here to test if I can figure out how to remove it without breaking it. Any ideas?
Old Mar 15, 2026 | 05:57 PM
michaelh's Avatar
It's incorporated in the dimmer control on the steering column.. From the drivers manual:
To operate: Rotate the knob to adjust the illumination to the required level.
To select 'override', turn the knob fully ant-clockwise.
It doesn't feel like a switch (in my car at least) - as you won't hear/feel any click.
According to the EG, the dimmer module itself is 'adjacent to the RHS fascia fusebox' which means it's behind the air vent and a PITA to get at.
Old Mar 15, 2026 | 06:45 PM
Pantera928's Avatar
@michaelh Thanks for the explanation on the dimmer override. Unfortunately, all the power to that dimmer goes away when the car is started and the lights are turned on. I found the dimmer module. I will try a swap out in a couple of days when I have times.
Thanks again
Dakota.
May 8, 2025 10:28 AM
Mike Starks
Feb 23, 2024 06:21 AM
cafexjs
Feb 26, 2023 02:05 PM
Catalyst
Sep 2, 2022 09:01 AM
agd
Oct 23, 2021 11:28 PM
