O2 Sensor Replacement
Old Nov 12, 2012 | 04:48 PM
johnpreston84's Avatar
Default O2 Sensor Replacement
Good Afternoon:
After doing some digging around, I have found that the wiring to the front O2 sensor on the passenger side of my XKR has been chewed up by some rodent
I have decided to give replacing it a go.
I have two questions:
1) How do you remove the protective silver covered plate that is protecting the 02 sensor? Is there anything else I should be be weary of before replacing?
2) Which Side is Bank A on the US Models.?
Thank you.
Old Nov 12, 2012 | 09:33 PM
WhiteXKR's Avatar
The A bank is passenger side on a 2001.
Are you talking about the stiff fiberglass-like material heatshields? They are just bolted on.
Access to the O2 sensors is very limited on the XKR, and they often require a huge amount of torque to remove. You may find it easier to remove the entire catalytic converter to get the sensors off.
Attached is my write-up on a catalytic converter upgrade, which will have useful information for this job.
Old Nov 13, 2012 | 09:35 AM
Spurlee's Avatar
If you can't or don't want to remove the cats spend some time and spray the O2 sensor with PB Blaster and give the bugs/threads a good whack with drift and hammer periodically. It helps to remove the sensor when it is hot either from a torch or from runing the engine.
PMKimpton
Aug 3, 2019 08:22 PM
tberg
Sep 7, 2015 07:32 AM
KarimPA
Sep 3, 2015 07:32 PM
innzane
Sep 2, 2015 10:08 AM
TC Johnson
Sep 2, 2015 09:30 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
