OBD protocool & scanner scare...
Old Jan 17, 2014 | 05:01 PM
Bhpbug's Avatar
Default OBD protocool & scanner scare...
I just picked up a new scanner, made by Strategic Ind. Thought I'd try It out today. Question... what obd protocol should I use when manually selecting a protocol? I get a connection error if I try J1850PWM. I can use ISO 9141 but... it trys to display fuel trims for B1, B2, B3, and B4??? Now, the last time I looked, I don't have a W 16 in my '03 xk8... I know it must be a protocol thing. BTW, fuel trims for B1 and B2 are fine, lt and st. the trims for B3 and B4 are a lot higher... it seem odd to me,
Should'nt I just see stft and ltft for only B1 and B2 ?... 4 numbers?
Also, could it do any harm if the wrong protocol is tried ? I tried to contact strategic but, they could not answer my question.
Thanks to all who reply, I'll keep researching in the mean time.
Old Jan 17, 2014 | 06:21 PM
RJ237's Avatar
When I first connected my Ultragauge, I did not select a protocol and after a few days the car started displaying gearbox error and went into limp mode. Forcing the ISO 9141 protocol solved the problem. You will probably have similar trouble.
Old Jan 17, 2014 | 07:03 PM
Bhpbug's Avatar
Thanks RJ237, I guess I'll just deal with, and use ISO9141. I guess I can just ignore the B3 and B4 fuel trim data... I can't help but wonder why this is though. FWIW, the car Runs GREAT! ... no codes... last 3 years.
philwarner
25
Jun 26, 2021 05:43 AM
carl purchase
Oct 14, 2015 06:14 PM
jjmiah217
Sep 28, 2015 09:09 AM
foxbottom
Sep 25, 2015 03:24 PM
