OBDI not working
Old Aug 24, 2018 | 08:36 PM
kenatofc's Avatar
Angry OBDI not working
Bought another OBDI reader: ADOTER ADN 200 which reportedly works with a 2002 Jaguar XKR but goes through all of the power up tests then indicates "COMMUNICATION ERROR"
Same thing with my other reader !!! Anyone have an answer ??
Thanks,
Ken in WV By Golly
Old Aug 24, 2018 | 09:56 PM
zray's Avatar
I don't have an answer. Sorry. But your experience mirrors mine 100%.
until I bought this product, I had 3 code readers fail to connect to my '02 XKR
Amazon Amazon
I'm not getting 100% usefulness from the icarsoft LR V-1, but at least it reads fault codes and can erase them most of the time satisfactorily .
If you find a better reader, please let me know.
this one might be better:
Amazon Amazon
but I have feeling it's going to take a lot more $$$ to have full connectivity with our cars.
Z
Old Aug 24, 2018 | 10:41 PM
fmertz's Avatar
See if you can "force" ISO-9141, the old serial protocol. The car has CAN and SCP, but OBDII is not available over those.
Old Aug 25, 2018 | 12:53 AM
JagV8's Avatar
Check fuses & relays that are in the circuit.
Old Aug 27, 2018 | 05:59 PM
Ophitoxaemia's Avatar
Is the key in the on position? My cheapo reader works fine.
Old Aug 27, 2018 | 06:05 PM
zray's Avatar
key on, motor running, no go until I used the icarsoft LR v1..
Z
Old Aug 27, 2018 | 06:23 PM
912guy's Avatar
I wish I could help you but I only use professional equipment in my shop... Autel and Launch make some cheaper units that connect very well...
Old Aug 27, 2018 | 06:31 PM
I've never read codes with the car running.
I had someone connect a code reader with my car running and it caused a 'Restricted Performance" error until I started it about 3 times.
Old Aug 27, 2018 | 09:05 PM
zray's Avatar
i guess I wasn't being very clear. I'm not checking for fault codes, I'm more interested in engine temperature, transmission temperature, oil pressure, etc. that kind of thing. Engine off would do me no good.
However, the cheapie code / data readers would not connect on my car engine off, engine on, nada.
Z
Old Aug 28, 2018 | 01:01 AM
JagV8's Avatar
You'll need OBD II not I.
Even the cheap ones should work but some are badly made - bit of a chancy business sadly.
Old Aug 28, 2018 | 09:55 AM
I see now. I bought a $20 transmitter that plugs into the ODB-II port and connects via Bluetooth to a free app on my Android phone. I can set up custom readouts/gauges.
I used this after fixing my octopus hose leaks to monitor coolant temp. Worked great.
Don't leave it plugged in though- drained my battery.
agd
Feb 11, 2023 03:54 AM
Bluecortina76
Sep 15, 2017 01:52 PM
M12345678
Jul 14, 2016 12:49 PM
zigzewel
Dec 10, 2015 03:31 PM
denisecdb
Apr 10, 2012 11:08 PM
